Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Noise - belt or bearing?
We have a noise and can't seem to see how to take the machine apart to get to the belt area - I have replaced belts and bearings before - but have never had this machine apart. Where can I find instructions?
  • 15,935 Answers
It appears your tub bearing assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Belt tensioner noise
You can use a funnel and a section of heater hose to listen around the area, just be careful and not get the hose caught in the belt.
Or you can take the belt off and turn the pulleys by hand to check for bearing noise.
Feb 24, 2013 | 2004 Suzuki Aerio
There are 3 belts on the truck (1994 V6, 4wd). The belt that goes around the alternator was not spinning and there was a loud screeching noise. I cut the alternator belt to see what the truck would do with...
The pulleys may be out of alignment due to a bent or misinstalled alternator bracket. the alternator itself may be pulling so much current that the belt is slipping on its pulley. (might be why the other alternator failed. Check the battery voltage with everything turned off and see if you have a parasitic battery drain.) The bearing for the idler pulley (if equipped) could be failing.
Feb 09, 2011 | Toyota Pickup Cars & Trucks
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
Noisy bearing
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Noise coming from the belts I suspect the bearing please help
    Belt noise can be silenced with the application of silicone spray to the belt. It won't hurt the belt at all. If it's a bad bearing the silicone spary won't quiet the noise. To locate the bad bearing use a short length of hose or tygon tubing. Watch out for moving parts. Listen in one end and point the opposite end of the hose to different areas/bearings. The noise will be louder when you locate the problem area. The same technique one would use to locate a vacuum leak. Again, watch out for moving parts.
    Jun 09, 2009 | 2004 Volkswagen Golf
    1991 park ave 190k miles, loud bearing noise from serpentine belt area at idle, goes away at speeds 10mph and up. has new water pump and alternator, belt is not jumping around, a/c is still cooling. noise...
    The serpentine belt area is large. Remove belt and spin the IDLER PULLY of the belt TENSIONER. and listen for a bearing noise. A common failure. Hope this helps
    Apr 30, 2009 | 1991 Buick Park Avenue
    Noise from area of serpentine belt.
    The best way I have found to locate a belt noise is to take a can of WD40 and spray it on the belt when the engine is running. (be careful of the fan) If the noise goes away, you know that it is a belt noise and not a bearing. When serpentine belts dry out they make funny noises. Hope this helps, cheers
    Apr 08, 2009 | 1993 Volkswagen Passat
    Loud Sqeaul/screech from engine upon start up
    could be your alternator. at start up. alternator usually has a big load because you just use your starter. it would recharge the battery and after a while the battery would be fully charge, the squealing noise will be gone.
    check also all the belts if they are individual belts. use some belt dressings to eliminate the noise. sometimes the belt are just worn out and it would also make these noises.
    tnx 4 using fixya,
    drcool
    Oct 14, 2008 | 2005 Dodge Caravan
    Kenmore 88732 Top Load Stacked Washer / Dryer Logo
    75 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
