Question about ATI RADEON™ 7000, (64 MB) AGP Graphic Card
Video cuts out suddenly, have to reboot
Problems with video cutting off suddenly. The screen goes black (blue, actually), then flashes the 'No Signal!' message for a few seconds, then the monitor shuts itself off (due to no signal). To recover I have to manually power the machine off and on.
I'm not playing games or doing anything graphics-intensive, or anything-intensive.
About half the time there are symptoms just before it happens - either the graphics slow down, for example it takes a long time to drag a window across the screen, or there's a slight hang after moving the mouse, then poof the video is gone.
Problem occurs about 90% of the time. Sometimes it happens immediately, on the first mouse move after Windows loads, other times it goes 10 or 20 minutes before crashing. About 10% of the time the problem does not occur.
This is an XP machine, generic PC clone about 5 yrs old. Device Mgr lists the display adapter as Radeon 7000. Sticker on video card says RV6D-B3-64M. When I google that I find "PowerColor ATI Radeon 7000 64MB DDR AGP" with pictures of green cards, but my card is red ...
Anyone's best guess as to most likely cause?
  • 1 more comment
  • cookie jones Feb 15, 2009
    Sorry for being dense (I'm not a hardware person), but how do I check? By opening up the case?
    OK, if I can figure out HOW to check the temp...
  • cookie jones Feb 19, 2009
    Interesting result. I opened the case and found tons of dust, the worst
    was a thick layer under the processor fan's blades. It took a while to
    brush and vaccuum it all away, but now instead of dust there's a set of
    shiny clean cooling fins under those blades. I cleaned the other fans (the power
    supply fan had a lot of dust, too, but not as bad), and rest of the
    case, then gave it a whirl. It has been working without crashing for
    several days now. (Yay!) You were right - it must have been
    overheating.
  • 77 Answers
Check to see if your video card is excessively hot. It sounds as if your video card is overheating and going into thermal protection.
A lot of times, when the GPU is damaged it will overheat as one of the final signs before it's impending death.
If this is the case I would replace it.
Posted on Feb 15, 2009
  • Randy
    Randy Feb 15, 2009
    YEs, take the cover off and hold your hand over the area where you monitor plugs into. However, you would most likely be best to take it to a shop for repair.
  • Randy
    Randy Feb 19, 2009
    glad I could help and glad it was just a dust buildup and not a faulty card :)
My Canon PowerShot SX230 HS cuts off after 10-14 seconds of recording. A yellow exclamation mark appears and shuts the video off. A green light flashes and says the word busy at the bottom of the screen....
There may be other causes for your experience but I am thinking of two and these are:
  1. The memory card - video recording is best achieved with a card of Class 4 or higher. Anything less will pose problems.
  2. Settings on camera auto-timeout - check to make sure the auto-time out is set to default.
Aug 20, 2013 | Canon PowerShot SX230 HS 12.1 MP CMOS...
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
360 just has blue screen
Check if it is on the right video imput or check the connections from your xbox to your tv via the three colored cables.
May 12, 2009 | Microsoft Xbox 360 Console
My psp froze
i understand ya... I used to deal with psp's before.
Now i want more info.
What model is it? and when you turn it on now what happens?...
This might require you to re-flash your psp.
and by how it sounds to me it seems like you dont really have much experience with psp's
Try searching on google for "Unbrick PSP" you will find more info.
Another way is to go on craigslist.org and search around your location for "psp" reapair ppl. Usually this should not cost more then 20 bucks.
Apr 24, 2009 | Sony Video Game Consoles & Games
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
Possibly Video Card problem?
Mikolan,
That is so crazy.
You say you previously was able to see the POST screen and now you can't?
You say you switched monitors and card outputs to no avail? Is the card an ATI with an aux Molex power connector?
Is the puter actually going into standby or hibernation?
Have a boot disk? or a PE?
How about a Linux self-install distibution CD. Just kidding about that last one. Not really, you can see if the puter does respond.
Don't rule out a faulty power supply. Video card fail is usually one long, two short beeps at POST. or 8 short.
Jun 09, 2008 | Computers & Internet
My philips 32 inch tv which is fifteen years old the tv works and then it cuts the video goes but the audio stays on then it will come back and then the video goes and becomes a black screen i know the tv...
your flyback transfomer may need to be solder around pinns or you have a bad capacitor in high voltage circuit.ThankYou for trying FixYa. Have a Nice Day. Call the repair shops see what they would charge to fix it.
Feb 20, 2008 | Televison & Video
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
ATI RADEON™ 7000, (64 MB) AGP Graphic Card Logo
265 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
