Question about Kenmore Elite 45986 Front Load Washer
I got an F error code the washer won't start
There was some water in the washer. It stopped before spinning.  I hit the drain spin button to try to get the water out.  The door lock works fine, but noting is happening....It is not draining or spinning.  I cancelled this since nothing was happening and tried all the different wash cycles....none of them are working.  First I had an F code. once I got a C1 code.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Try unplugging the washer for AT LEAST 30 minutes. This will reset the CCU. If the washer continues to exhibit problems, post back with the error code you are getting. The C1 code is normally the beginning segment of diagnostics mode.
  • 15,935 Answers
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
First washer would not fill tried later it started got to spin stop will not empty water tried drain and spin button still wont run help thank you happy hoildays joe thomas
Suds detection & long drain error codes indicate a problem with the water draining out or too much soap is being used. If the unit is not draining good then I would suspect a problem with the pump or control board. Please see the images provided for more details. Press stop twice to reset the control.
Dec 17, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
No error codes-washes but does not spin- water stuck in bottom
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If you lift the washer lid and rotate the wash basket CCW which is the Spin Cycle direction will it turn with very little resistance? It should not rotate CW.
With no error codes I would go to Service Mode page 14 of the Service Manual and read the current recorded Daig codes and write them down then clear the list.
Now start a Spin Only cycle with no clothes in the wash basket let it in that mode for about 5 minutes. Hit the off button to end the Spin Onlly cycle then check the Diag code block and see if an error event was logged if so please let us know.
If there is no error code generation by the Control Board in the Diag code blocks I would suspect a Control Board issue with your no Spin issue..
Without a known good Control Board and Motor Controller to swap out and no error code generation by the Control Board this would be a hard problem to troubleshoot.
The Control Board is under warranty for 5 yrs you could try Maytag Customer Service the number is in the SM and see if they will send you one even if the warranty is up…..Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent compartment
Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach compartment
Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
Turn the program knob (4) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.When the door is
opened, the drum light should turn on.
Turn the program knob (5) clicks from the start
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
Turn the program knob (6) clicks from the start
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Robert Rankin
