Question about LG Flatron 795FT Plus Monitor
I've fried my monitor - Won't power on
Hi, I connected my 795FT to my XBox using an VGA cable which I fabricated myself. Problem is I think one of the pins was connected incorrectly and has fried my monitor. When I first connected the cable the monitor was already powered on and showing the OSD. As soon as the cable was attached the screen went blank. As soon as the cable was disconnected the OSD reappeared. On connecting the cable again the screen went blank and the whole monitor seemed to power down and will not power up again. I have checked the external power and internal fuse, both are fine. I have downloaded the service manual for this model and am about to step through the checklist. (Checking diodes and caps etc.) However this is the first time I've tried anything like this and I would like some advice as to whether I'm likely to be wasting my time or not. Cheers, Chris
  • weirdwildpla Feb 16, 2009
    Thanks for your reply, Leroyal. I've Googled a couple of the parts and think I may be able to get hold of them athough, I agree, it's not gonna be easy.
    I got my multimeter out this evening and started going through the troubleshooting guide in the service manual. I noticed that one of the heat sinks is charged to around 150v - is this normal?
    Genius:
  • 2,120 Answers
It will be almost impossible to find these components unless you are in Taiwan.
Posted on Feb 15, 2009
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
How do we connect xbox consul to imac and play
There is no way to connect the original XBox console to an imac's monitor. There was never an hdmi or VGA connector that was worth buying made for the Original XBox.
The XBox 360 has a nice VGA adapter. But no the original XBox, sorry!
Apr 14, 2010 | Microsoft Xbox Console
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
Monitor LED blinking--no display--How to open the cabinet
check the vga cable if it is attached properly to your computer. Make sure that the VGA cable is connected to the Video Card that you are using.
check in the manual if you need to install the driver first.
also check if the monitor will work to another computer. If not, Then you can check the VGA Cable and replace a new one.
Hope this will help you out .. =)
Aug 24, 2009 | LG Studioworks 700S 17" CRT Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
Monitor no longer will switch to Analog (VGA) source.
try to Lower the resolutionof your monitor.
Mar 02, 2008 | Computers & Internet
LG Flatron 795FT - Led blinking
there is a step by step procedure 1.check the power cord. (try with a new one) 2.check the monitor on other pc, even if it is not working on the other pc, then carry to a service centre. 3.if it is working on the other pc then check the vga slot/card of your pc then 4.try to change the vga card and try connect an other monitor to your pc. so basing on this you will be able to trace the problem. 5.still the problem persists the consult the service centre.
Apr 05, 2007 | LG Flatron 795FT (White) 17" CRT Monitor
LG Flatron 795FT Plus Monitor Logo
107 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
