Question about Samsung HL-S4266W 42" HDTV
Numerous white spots on Smasung DLP TV
White spots are just emerging on my 50 inch Samsung DLP TV everyday. It started with one two days ago and now there are almost 30, I gueww in two weeks the sreen would be covered.
Help I have the same issue with my TV.  I just sent an email to samsung and hope they respond.
  • 1 more comment
  • Anonymous Mar 11, 2009
    I have same problem .
    white spot from 20 to 300 right now
  • Anonymous Apr 02, 2009
    Same problem - white and black spots increasing over time - Samsung service says they have never heard of this and says entire screen needs to be replaced. My set was less than two years old and used lightly.
  • Frenchie2009 May 04, 2009
    My 42 inch tv started showing white spots on the screen a couple of days ago. The number seems to increase now. Anyone has a clue of the issue and the resolution.
    Thanks,
  • Samsung Master
  • 5,138 Answers
BAD LIGHT ENGINE call UED 1-800-648-6657
Posted on Feb 16, 2009
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
above information is a bit extreme - most likely culprit is dirt/dust on reflecting mirror.....
Aug 27, 2009 | Samsung HL-S4266W 42" HDTV
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
http://www.discount-merchant.com/SearchResults.asp?Search=dmd
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mine is having the same problem. It started around Memorial Day and is only getting worse. One white dot is now a dozen. I called Samsung several times and was given the brush off. They clearly know this is a problem and are failing to respond to the problem in hopes that people will deal with it on their own. It does not matter if your warranty is expired. This is a latent product defect. They are still liable and obligated to fix the problem. I have filed a complaint with the better business bureau. If the company does not respond, I'm taking this to small claims court to get reimbursed for any cost to fix my tv.
Jun 02, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Feb 26, 2009 | Samsung HLS4676S Television
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-S4266W 42" HDTV Logo
1,169 people viewed this question
Henry  Thomas
Henry Thomas
