Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic cinemavision pt-53wx54j
My tv do not turn on and led blinking
  • 2 more comments
  • jbaezr1 Feb 16, 2009
    led is blinking 5 times
  • rewing402 Mar 07, 2009
    still blinks 5 times when turning it on
    now read this one said 3 blinks and the problem is 5 blinks
    Slinteriors
    Rank: Guru
    Rating: 89%, 2828 votes
    if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
    Comment posted on Feb 16, 20095 blinks means IC4511 is defective or not functioning properly
    Rating Locked! (?) jbaezr1 has rated this solution as Helpful
  • nova71977 May 10, 2009
    same problem
  • Panasonic Master
  • 8,617 Answers
If the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Posted on Feb 16, 2009
  • Sonny Berry
    Sonny Berry Feb 16, 2009
Were can i get an ic451?
Posted on Feb 18, 2009
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Panasonic cinema vision pt-53wx54j does not turn on. red power led blinks 3 times.
Hi
Thanks for using FixYa. 3 blinks means convergence output failure and to resolve this you’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Panasonic PT-53X54 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Helpme
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
Dec 14, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
1,112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
