Question about Danby DCD5505W Electric Dryer
Danby dryer has stopped spinning
I want to check on and/or replace the belt.
It is a a front load.
How do I open the machine?
  • Anonymous Mar 10, 2009
    The dryer stopped spinning, I took off the access door on the bottom and the broken belt fell out. Where do I get another belt and how do I install it?
  • Anonymous Mar 15, 2009
    Can't find dryer belt mine stop spinning friday
  • 20 Answers
Here are the Danbyinstructions:
INSTRUCTIONS TO CHANGEDRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF
THE FRONT THAT GO FROM BOTTOM UP. REMOVETHE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK ANDLIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THATHOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREWFROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACHSIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWSAROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVETHE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THEBELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THEBLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Posted on May 23, 2010
Lg washing machine is making a squeaking sound and not spinning dry. Do I need to replace the belt? 7.5kg washer model WD-1018C
check the belt tension before replacing. there should be about 1/2" deflection (play) on the longest open side of the belt.
Mar 21, 2014 | LG WM1812C Front Load Washer
Motor hums when you start button, will start with low load, but not full load. How do I open the front to check the belts, model number lg8409w2
You did not say what make your Dryer was so I gave you the basic
________________________________________________________
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Sep 26, 2010 | Dryers
My washer is smoking and wont stop spining after a cycle i assume this is the belt and i am going to replace it but right now i am having trouble opening the front or back whichever i need to get to the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | General Electric WHDRE526EWW Top Load...
What do do when it does not squize
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 07, 2010 | Washing Machines
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
The washing machine does not spin but its not the belt. It dies all the other functions except that. what can be the problem and what is the solution?
If the machine will spin but not agitate, then the transmission needs to be checked. You should probably get an estimate from an appliance tech to see if it is better to replace the part or the machine.
May 04, 2010 | Danby DWM5500 Front Load Washer
My front load washer won't spin
Hi There,
If your washer does not spin there might be two conditions:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. If the problem lies here Call a qualified appliance repair technician.
If none of these work then Do get back to us for any further assistance........
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Front load shows wash but basket not moving
I FOUND A BELT POPPED OFF OF A MODEL LIKE YOURS ONE TIME. TAKE THE BACK PANNEL OFF AND SEE IF YOUR BELT FELL OFF. UNPLUG YOUR MACHINE FIRST! AND IF YOUR BELT IS OFF CHECK YOUR PULLY IT MAY BE LOOSE IF SO REPLACE IT AND YOUR BELT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Danby DCD5505W Electric Dryer Logo
356 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
