Question about Microsoft HP Pavilion DV6276US Notebook PC
I have an hp dv9933cl notebook pc and am having volume troubles
The big volume bar pops up on my screen when i use the volume buttons on the computer. it freezes the program i have running and makes it go slow. I know about the msconfig solution but i can't find the quick touch on screen display under any of the tabs
  • 4 more comments
  • Anonymous Feb 24, 2009
    every time i try to raise or lower the sound using the quick tuch bar the volume keeps flashing and even when i restart the computer it still continues
  • Anonymous Mar 11, 2009
  • JohnnyG1 Mar 17, 2009
    My problem is very similar, almost everytime (not always - does not happen in Windows Media Player) when I touch the volume bar, it pops up that large volume bar window, which pulsates and freezes the underlying application. Depending on the length of my touch on the volume pad, it will stay frozen proportionally as long. When you wait a while (sometimes a very long time like 2 minutes), it finally goes away and unfreezes the application. Very annoying and very frustrating! Is there a way to disable the popup window? This might be causing it. btw, I'm on Vista..
    oh and I am running on an HP Pavilion dv6000 so it's definitely OS related.
  • zro77 Mar 31, 2009
    same prob w/ HP DV7 Notebook
  • Anonymous Apr 19, 2009
    i know about the msconfig thing, but I dont know where to find the quick touch on screen display. please help me!
Screen flicker
Check the ram first then check the screen cable
Nov 20, 2013 | HP Pavilion dv9933cl PC Notebook
Manual service
It is probably a GPU overheat issue where the BGA chip has desoldered itself.
Reballing the GPU should fix it.
I have a HP Pavilion Entertainment Notebook. The volume bar has not only stopped working, but the volume icon now just just pops up randomly and will not let me type or click on anything. It has held my...
As odd as this may sound, it sounds like a problem in your keyboard. Make sure the volume button(s) or mute button is not partially depressed and stuck, and hasn't had anything spilled in/on it. If it's not that, you've probably got bigger issues that are going to take some qualified repair work, like parts swaps.
Jul 06, 2011 | HP Pavilion dv4000 Notebook
I have an HP Pavilion dv 7 notebook pc. not sure why... in the middle of my screen a bar shows up with the word "volume" and a sound bar indicating that volume is twitching between 35% and 50%...
no photos , no joy
why post this lacking that,
remove all USB devices first. see if that cures it.
is the device manager showing errors on the onboard, sound chip>
my be bad keys for sound controls, (switches)
the hot keys are function keys on mine, see them>?
on mine if the hot keys strip is bad or the software to it drivers
bad to sound or the HP key strip (see the vol, updown buttons?) has bad driver there, it will mess up.
why not get a tech to fix this?
May 29, 2017 | HP DV9626US Pavilion Notebook
The volume slider on your laptop is failing or having problems, I have had this issue my self it is usually caused by dirt and grime, so you may want to give it a good cleaning or residual heat from the processor. I'm posting the link to an hp support thread below, with several other fixes not mentioned here. I hope I could Help.
http://h30434.www3.hp.com/t5/Notebook-Hardware/HP-Pavilion-dv7-1240us-volume-control-touch-sensitive-not/td-p/39547
Jun 21, 2011 | HP Pavilion dv6000z Notebook
Process smartmenu.exe has a volume bar that
first of all u have to remove it from ur startup menu then search any service which support this process and remove it from ur startup Services.
procedure:
window+R
type msconfig and press OK
do above procedure
Aug 03, 2009 | HP Pavilion dv7-1240us Notebook
Volume bar won't go away
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
went to hp and talked to a support person who gave me this driver update: ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe.. visit their website this is a pretty common probem....
Nov 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Touch Volume
really? i mean my computer was 3 days old, and i have the newest anti-virus and spyware programs running at an enourmous cost to myself...the patch i got from the hp tech online help was this...
Robert: Here is the link for HP QuickTouch Software.
Robert: ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37799.exe
Robert: Please do not click on the link instead, Just copy and paste the entire link onto the address bar of your browser and press .
david hodgkins: should i uninstall the current drivers, or will they be automatically replaced?
Robert: The driver will be replaced.
david hodgkins: thanx!
Robert: Please hold on.
david hodgkins: i've already completed the download
Robert: Here is the link for HP Quick Launch Buttons.
Robert: ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38171.exe
Robert: First download it on to the desktop. Then double click on it to run the file; Once the installation completed, restart the system
this may, or may not work...the tech informed me that the firmware, or the original drivers were corrupt when installed and that this patch should work.
have a nice day,
david
Jul 24, 2008 | HP Pavilion dv2500t Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
514 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
