Question about Epson Stylus C62 InkJet Printer
Grinding noise and won't print
After I turn on the printer it makes a grinding noise and then turns off.
  • 353 Answers
When you say "it turns off" do you mean both the lights go off as if you'd pulled the plug out, or do you mean it stops working but with lights still on or flashing. If it's the latter, can you have a look at:
and take action to correct the problem indicated by the lights.
If this has been helpful, please rate it, otherwise come back with further information about the problem and what you have done so far.
Posted on Feb 17, 2009
  • Gerry Millward
    Gerry Millward Feb 17, 2009
    The section you want in the Reference Guide is Problem Solver - Diagnosing the Problem - Error Indicators
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Grinding noise when printing
Apr 12, 2010 | Brother HL-2070N Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
Mar 18, 2009 | Samsung CLP 300 Laser Printer
Cradle made grinding noise and now machine wno't turn on
My Alps printer makes a grinding noise and won't pull the paper through much less print. What do I do - I print diplomas with this printer.
Apr 30, 2008 | Office Equipment & Supplies
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Oct 31, 2007 | OKI C5150n Led Printer
Epson Stylus C62 InkJet Printer Logo
325 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
