Question about Kirby G6 Bagged Upright Vacuum
Just stopped running while vacuuming
Took it apart and it is not getting power to the motor. Checked the cord and it is fine.
    President:
  • 389 Answers
When a vacuum cuts out while working, it usually indicates overheating. Most have a thermal cut-out, which will reset itself if given time to cool. The cause is usually a blockage of some sort.
Posted on Feb 18, 2009
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
I have power and air suction, but the beater will not turn and the belt is fine.
Check that you are getting power to the brush roll motor. Many Rainbows have a reset button on the power head.
Jan 31, 2014 | Rainbow Vacuums
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
I have a Karcher WD 3.500 P wet dry vac. First ? when vacuuming dirt off floor do I always need the bag or is the cartridge primary filter ok.. I clean it regularly. Second problem. I went to turn on...
The bag is part of the filtration design of the machine. Using it will not only make your primary cartridge filter last longer, but make the vacuum suck more efficiently & make your vacuum as a whole last longer.
You can bypass the switch to check if the motor is okay.
More often than not an intermittent operation of a machine is actually due to a break in the power lead. This is not always apparent externally though. You may need to get this checked by a qualified / certified person.
Mar 29, 2017 | Vacuums
I have a problem with a miele s524 canister vacuum. While the motor is running and you pull out the power cord for more length it shuts off.
Be careful here, the cord inside is connected somewhere to the unit and it may have come loose (the connection) If you can safely get it apart a look will show where the issue is but I would also suggest having a shop do that for you--better safe than sorry.
Dec 18, 2012 | Miele S524 Mercury Bagged Canister Vacuum
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
I accidentally ran over the cord and then machine motor slowed down and stopped running. It wouldn't turn back on
get a new cord. It was stretched and ripped apart under the outer rubber cords housing insulation
Sep 01, 2010 | Kirby G4 Bagged Upright Vacuum
Motor not turning
Don't forget, the agitator bursh doesn't work when the vacuum is upright. Maybe that is your problem.
Apr 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Dog chewed power cord
you have to take the machine completely apart and get inside where the motor is.take the cover off there are 3 screws 2 on the left side behind the hose and 1 on the right side back by the wheel.that will take the covr off.now where the upright sets on the base you will see a ******** each side of the motor, take those off,that will seperate the upright from the base.now you have to open the motor housing,there are 4 screws 2 on the front side and 2 on the bach side that will expose the motor and the cord.take out the old cord and splice in the new one.then put it all back together in reverse of how you took it apart.please leave feedback
Feb 27, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Kirby G6 Bagged Upright Vacuum Logo
244 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
