Question about Dell Inspiron 1501 Notebook
Fan constantly running
I've just bought a USB microphone (audio-technica) to record voice-overs on my Inspiron 1501 though everytime I attach it the fan revs up causing unwanted background noise. Is there anyway of disabling it even for a short while?
  • Felinna
    Felinna May 11, 2010
    If you stop the fan, the computer will heat up and shut down to prevent chips from releasing toxic silicone. I don't think you can shut it down, anyway. but I don't think the fan should be rewing up cause of the mic ... you sure your sound card is working ok and not overheating because of the mic?
    also, the fan should still be quiet enough not to disturb the mic ... or does the mic record the sound via the input cable and connectors? mine did that
  • 60 Answers
Disabling fan may cause a hardware problem. So im not responsible for that.
Open the fan from hardware. It will have two wire in its back which is fans power cable. Cut anyone and attach a small off/on switch (small bed switch will be better) between two edge of the cutted wire. Done. You can control the fan by this switch.
Keep informing.
Posted on Feb 23, 2009
I can hear people on msn but people can not hear me
The Dell Inspiron 1501 has a set of internal speakers but doesn't have a built-in microphone. You need to plug an external microphone into the microphone jack on the right side of the notebook as shown below. You can open Messenger and click on the Tools tab then select Audio and video setup. (note as there is no built-in webcam, it will just be an audio setup). You may decide later to add a USB webcam with a built-in microphone in which case the plug-in external microphone will no longer be required.
Mar 26, 2011 | Dell Inspiron 1501 Notebook
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
When i recored my vocals they are delayed so it goes over the beat instead of being on top of it and right on point
This is a common problem with recording multi-track sounds on a computer. It is caused by something that is known as 'latency' - basically it is down to the fact that the signal from your microphone takes a different route through the system to that taken by the audio playback. The AT2020 is a USB microphone and the signal therefore has to pass through the USB bus circuit of your computer. Despite claims of multi-tasking your computer cannot do everything at once so it naturally creates delays to make itself work properly. This will be more of a problem with a computer which has a 'cut-down' processor such as a Celeron (Intel) or Duron/Sempron (AMD). These processors are really only intended for basic computing (office type) use and are not really up to the high demands of video or audio recordings.
You may get some improvement by tweaking some of the audio settings for your sound-card to change the hardware acceleration.
This article may help you http://www.pcmus.com/latency.htm
If you are using a dedicated midi /music recording program such as Cubase then you may be able to correct the time lag using the 'quantise' function after recording your vocals. However the best solution is likely to be a hardware one Either buy a proper multi-track mixer/recorder designed for the purpose or get a second USB microphone - play your backing track on an external device - using one microphone to capture your voice and one to re-record the backing track (the only downside for this second option will be a gradual degrading of the sound quality each time it is re-cycled)
What drivers can i download to make my at2020 usb work with windows vista
i hav just bought a at2020 mic and i tried recording bought it's not workin for my dell inspiron i forgot the model anyway it's running on windows 7 so please help me out am screwed with this ****
Mar 13, 2010 | Audio Technica Audio-Technica AT2020 -...
My church bought 4 audio technica free way 700 series microphones about a year ago and from the beginning we had problems with them. Now only one of them is working! There is no warranty and we really need...
Audio Technica is generally a good brand name in microphones, but sometimes if you talk to musicians they tend to favor names they are familiar with like Sure. In the church, school, venue world, audio technica is respected. I work audio in three separate venues and we have no trouble with our audio technica microphones.
Have you adjusted the channels--and have you tried to do so manually? Have plugged the working one into the same inputs the nonworking ones were plugged into? I know it sounds like a simple thing to ask, but sometimes the connections to the sound board are the issue. If you have the more advanced receiver for the freeway 700, there are other adjustments designed to allow you to adjust between guitar and voice. If it is preset to guitar it will not sound good for voice. You may have to change that. I am assuming you put in new batteries, but ifyou have not, you may want to try that as wireless mics use up batteries quickly.
Those are a few possibilities. If it is the actual unit, then you can look inside and see if something is loose, but as far as repair, that gets into a whole issue. Hopefully something above helps solve the problem
Sep 06, 2009 | Dual Audio-Technica ATM250DE Microphone
Audio-Technica AT2020 low audio output
Pins 2&3 are the correct ones to use for checking the voice coil. Pin 1 is chassis ground and should always read infinite resistance to the other two.
That microphone has an impedance of 100 ohms, so if you are reading 30 ohms you clearly have a problem with the voice coil.
Good Luck
BB
May 16, 2009 | Audio Technica Audio-Technica AT2020...
Microphone gives a really boomy distorted sounds on certain chords with an acoustic guitar
Hi Nic
Thats exactly how you do it:) Some times it doesnt matter what you do, you will get strange resonances. Careful EQ is the best way to tone it down. Some guitars will present boominess on certain notes, thats just the way they are. Acoustics rely on this boominess to some degree. Good luck and happy recording. :) Happy to talk more to you about it.
regards
robotek
Oct 31, 2008 | Audio Technica Audio-Technica AT2020...
Dell Inspiron 1501 Notebook Logo
195 people viewed this question
Alun Cox
