Question about Cherokee (REF) AM/FM Stereo with CD Player and Hands-Free Capability
Fuel pump doesn't work
When I turn the ignition to ON position (not start it) the fuel pump doesn't make the noise and if it doesn't the car wouldn't start
But if the fuel pump makes the noise the car would start without a problem. Once it starts and I turn the car off and restart without a problem again. That first cold start for some reason is tough.
I changed the relay and the fuel pump already, something is causing fuel pump not to start each time. But once it starts it keeps going, no problem.
2 Suggested Answers
  • 2039 Answers
SOURCE: 1997 Grand Cherokee - Car won't start
lot of time the idle air control closed completly try to starts the truck and pressing the gas pedal bit if it start you gonna have to press the gas pedal to keep it running and it should ajust itself thanks for using fixya pierre
Posted on Feb 16, 2008
Turns over acts like it string to start just doesn't
Try pushing the automatic fuel shut off button located on the left side of the steering wheel or in the glove compartment If that doesnt work then you should make sure the fuel pump is pumping fuel by listening for it to power on when you turn your ignition key
Mar 08, 2014 | 1998 Ford Explorer
Wants to turn over
Fuel pump? Listen for it to turn on when key is turned to on. May need to stand by the gas tank with the cap off. It should come on for a couple of seconds to pressurize the lines. If no noise, find the fuel pump relay under the hood and put your finger on it while someone turns key to on. You should hear it or feel it click. If not, need to check wiring in pump circuit. If it does click, but pump doesn't come on, check for power at the fuel pump connector at the gas tank. There should be power on the fuel pump wire when the engine is cranking. If not, again it's a problem in the wiring circuit. If it does have power and pump won't work, the pump has probably failed. The gas tank will have to be removed and pump replaced. Not recommended to buy after market pumps, spend the extra for genuine parts. It will save you grief.
If pump works and still a gas problem, check fuel pressure with a pressure gauge-should have around 40-50 psi. If good, check that fuel injectors are pulsing.
If not a gas problem, check for spark at the spark plug end of a plug wire. If no spark, ignition circuit will have to be diagnosed. Possibly a crank position sensor. Computer needs that sensor information to initiate spark.
Check for trouble codes from the engine computer.
Good luck.
Jul 19, 2013 | 1995 Pontiac Bonneville
Car wont start
replace fuel filter.listen for fuel pump operation with ignition switch on position for 3 seconds should hear fuel pump running should have humming or churling noise if so fuel pump working if hear no noise fuel pump faulty or could have blowed fuel pump fuse or bad relay.if fuel system okay problem could be ignition timing off due to worn broken timing belt.could have faulty ignition module.bad crankshaft sensor or camshaft sensor best to have vechicle code scan first before buying alot of new parts.could have bad ECM. many things will cause no start problems i.dont know model type vechicle.could have bad spark plugs wires. distributor cap and rotor could be bad.ignition coil could be bad.
Mar 28, 2013 | Cars & Trucks
Vehicle will not start, normally when ignition is in on position there is a whining noise for a few seconds, I wait until the whining stops and then start the vehicle. Now, when ignition is on on position...
Hi. The whining noise you hear is the fuel pump priming the fuel lines. If you don't hear the sound anymore then your fuel pump has stopped working. Check your fuses. Also look for a relay for the fuel pump. The relay will usually be in a large box under the hook that says fuse and relay panel or something similar. If the fuses and relay are working the the pump will probably need to be replaced.
Jun 12, 2011 | 1996 Ford Explorer
Car started stalling then stopped, will not start
SOUND LIKE FUEL PUMP.LISTEN FOR FUEL PUMP OPERATING BY TURN IGNITION TO THE ON POSITION.YOU SHOULD HEAR FUEL PUMP RUN FOR 3 SECONDS AND TURN OFF.IF YES REPLACE FUEL FILTER.IF YOU HEAR NO FUEL PUMP NOISE.CHECK FUEL PUMP FUSE AND RELAY.IF BOTH OKAY.CODE SCAN CAR FIRST BEFORE BUYING NEW FUEL PUMP.BECAUSE FAULT IN THE THEFT SECURITY SYSTEM AND PCM WILL DISABLE FUEL SYSTEM.
Jun 10, 2011 | 1994 Pontiac Grand Am
2002 lancer wont start unless throttlebox gets direct gas or starting fluid
test for fuel pressure. It could be fuel delivery related.
Feb 20, 2011 | 2002 Mitsubishi Lancer
Car won't start, error cc, Starter turns over, battery is strong, just doesn't ignite.
fuel issue, maybe fuel pump, turn key to on position and you should hear a noise coming from the tank, if you don't the pump, fuse, or relay is bad,.. 9 times out of 10 its the pump.if you do hear a noise then its probably a clogged fuel filter.
May 10, 2010 | 2002 Chevrolet Malibu
94 acura turn over but does not start, i pulled a spark plug wire when it was running and it die on me
get into car with windows up close doors so its quiet put key into ignition turn key to on position do not try and start it. when you turn the to on position listen you should hear a hum noise from the fuel tank that will be your fuel pump working the hum will only last about 2 to 5 seconds if you dont hear a hum could mean fuel pumps noy working.
Apr 19, 2010 | 1992 Acura Integra Hatchback
SENDING UNIT ???????
most of fuel pumps were in tank, wire corrodes is harness under right front seat floor pan to tank
if fuel pump buzz is heard and car runs and when it doesnt run you cant hear the fuel pump try
turn ignition off wait 10 seconds
turn ignition to on position to (prime or hear pump buzz)
no buzz fuel pump not working check fuel pump relay(swap with another) and try again?
you could use test light to pump wiring and make sure your getting power to pump on this prime test no power relay or wiring problem.
power at pump, but no buzz fuel pump faulty
Jul 01, 2009 | 1997 Isuzu Rodeo
Car Audio & Video Logo
87 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
