Question about Canon PIXMA iP4000 InkJet Photo Printer
Print test pattern
I wanted to know how to print a test pattern with the canon pixma ip4000
    President:
  • 2,692 Answers
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Cleaning/replacement of Nozzles of Pixma iP4000 Canon Printer
My Canon Primax ip4000 has stopped printing blue. I've tried deep cleaning and when I print a test page the blue 6c does not appear. Any ideas what the problem could be?
Nov 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
All prints come out with a green cast- all the color cartridges are full and installed properly and I downloaded an updated driver from your website-please advise.
a green cast usually means the red color is failing to print. In that case replace the color cart or take that cart to be cleaned, refilled, and tested.
Oct 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 has five cartridges 6BLK,e3BLK,6y,6m,6c
You may want to puschace and use a cleaning cartridge but positive results are not guaranteed. It depend how bad your print head is clogged.
The cost is about $5.
Google it (canon printer cleaning cartridge)
Nov 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
151 people viewed this question
old marine
old marine
