Question about Zanussi ZWF1430W Front Load Washer
I want to replace door seal on zannusi washing machine with new s
How
  • 32 Answers
Hi, they are a nightmare to do. Firstly remove the top (2 screws at the back) , then the back half chassis (2 screws at the bottom, 2 screws on the sides, beneath a round cap). remove the inlet valves holder and then the back half chassis. get someone to help at this stage. get the drum out of the front half chassis (side springs) and tilt it outwards. ask your helper to hold it. remove the bolts holding the counter weight (concrete block) and them remove the old seal. make sure when you fir new seal it's on right position. reverse the process.Cheers
Posted on Feb 15, 2009
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
How to replace door seal on washing machine Bosch Advantixx ?
How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
Feb 17, 2016 | Bosch Washing Machines
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Jun 27, 2012 | Beko WM5140W
How to remove door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko Complete Door Wm1510w 2816000500 Wma10w Wm1510w washing machine How to Replace Beko washing Machine Door Seal
Apr 24, 2012 | Beko Complete Door Wm1510w 2816000500...
The plug on my 6 year old Zannusi washing machine has just burnt out. Is it safe to replace it and try again?
No it would not be safe to fit a new plug and try again. If the plug burned out it would appear that there's a short circuit somewhere in the machine possibly caused by a leak. If you replace the plug you risk burning down the house or electrocuting yourself. I'd advise you to get a repairs man to check out the machine to see if it's repairable. It could be something as simple as needing a new door seal which would cost you around 30 euros.
Aug 31, 2010 | Washing Machines
Zanussi washer dryer jet system does not work
Hi, this problem is caused by the recirculation pump which has either gone faulty or has been clogged up by to much washing powder/liquid! you will need to strip the machine top off first then the rear and the pump is located at the rear of the machine (depending on model ) it is easy to spot as it is the only one that has the hose attached to the pump which leads to the door seal. take it off check for blockages in the pump and pipe and hose if no blockage then replace pump. It will then work like new.........!
Good luck...................
Nov 20, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
ZANNUSI TD900 Product Number 916110209 Doors can not open
Click on your brand (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Press "end of cycle" button & wait for 2 minutes before trying the door gently; do not force the door. & rate me if helped on this great site!!
Jan 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
187 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
