SOURCE: could you help
http://safemanuals.com/user_guide_instructions_ owner_manual_ALPINE_MRD-M500_M300.htm
SOURCE: alpine mrd-m500
Hi SPDGOD, Could not find exact, but close manual. It is the MRP-M450 mono block amp from alpine. Go to this url and view in Adobe. Print it if you need to http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
SOURCE: alpine amp mrd-m605
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
SOURCE: Really need the instruction manual for alpine mrd
CLICK HERE for a direct PDF Download.
Thanks for using FixYa - a FixYa rating is appreciated!!
SOURCE: alpine mrd-m501 amp
the subs cant handle all the power you got it set on turn off all the settings and then turn off your car and remove your face plate and then it should be ok. it does that because the subs cant handle the settings you might just have them a lil high
Hi SPDGOD,
