Zanussi ZT485 Built-in Dishwasher
Problem for Zanussi ZT485 Built-in Dishwasher
Blowing the electrics
By not_a_clue on Aug 01, 2007
our dishwasher blew th electrics during a normal cycle - thre is now water in the dishwasher that we cannot drain. Everytime we now switch it on it blows the electrics again.
Is there a way to drain out the excess water???
Comments:
Aug 02, 2007
- Thanks for the advice, will let you know the results!!!!
Best Solution
posted on Aug 01, 2007
Helpful)
zeusfaber
Rank: Guru
Rating: 87%, 343 votes
You need to get to the drain hose (always a bit fiddly with a built-in model). Look at how it is routed (the position of the highest point is important for later), then extract it from its connection to the mains drainage, and use it to empty the machine into a shallow container placed lower than the dishwasher.
As soon as the whole hose gets below the water level in the machine, it will start to drain. Because shallow containers tend to fill quickly and are then hard to move away, you may want to take several bites at this: Every time you want it to stop, lift the free end of the hose above the water level and secure it there so it doesn't fall off when your back is turned.
When the machine is empty, put the hose back where you got it from, paying particular attention to where the highest point in the hose goes.
In terms of what's blowing the electrics: Unless you know the machine has suffered physical damage from some external mishap, the usual culprit is pinhole corrosion in the jacket of the heating element letting water in to compromise the insulation.
To prove the fault: Disconnect electrical power. Find the electrical connections to the element and pull off the two that go to insulated spade terminals (the one that goes straight to the body is the earth, and should be left on). Tie the bare wire ends off with insulating tape so they don't touch anything they shouldn't. Reconnect the power and try to run a cycle. Even though the cycle is unlikely to complete properly in this condition, you will know the original fault lay with the element if the machine manages not to blow the electrics any more.
New elements are not usually difficult to fit - expect to pay about £40 for the one for your machine.
A.
Was this helpful?
Yes
No
Solution #2
posted on Jul 18, 2008
Not Rated)
flapjack937
Rank: Wiz
Rating: 78%, 61 votes
Urgent - do not use this again until an electrician has viewed it. There is a short somewhere, which is why it is blowing the electrics, and since we are talking water here, you need to unplug it and get it checked. A frayed cable may be touching a part ot the steel frame, which will make the whole unit live, which can kill. This is why it is blowing the electrics.No quickfixes here, get an expert.
Was this helpful?
Yes
No
Popular Solutions for Zanussi ZT485 Built-in
Questions and Unsolved Problems for Zanussi ZT485 Built-in
Do you recommend Zanussi ZT485 Built-in Dishwasher?
Answer
Answer
green light over rinse and hold flashes quickly
Answer
my zanussi dishwasher zsf4123s stopped getting hot,i bought a new heating element but still does not... (More)
Answer
I have a zanussi integrated dishwasher, have used it today, its lit on end of cycle, i have tried to... (More)
Answer
How do you remove the heating Element as I think mine has blown & want to check it..??... (More)
Answer
when turn on the machine, the all lights on but not working.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi ZT485 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
