Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Culligan AC-30 R/O filter change
What is the procudure for changing the 4 filters in a culligan AC-30 R/O water filtration system?
  • 13 Answers
Please see the below link for a pdf file and it should explain the procudure for filter changes for the Culligan AC-30 RO Water System
http://www.freshwatersystems.com/support/AC-30.pdf
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on May 01, 2009
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
Change filters on culligan h-83
You can get replacement cartridges for all the H series through AC series RO systems on line from several suppliers. I use them and they work just fine.
RJH2O
Mar 20, 2013 | Culligan Under Sink Water Filter
Culligan AC-30 osmosis water system housing leak
Depending on which type of plastic you have, it should say on it somewhere and it should look like a triangle and it will tell u pvc or nilon or abc. Then go get that type of glue and seal it with the correct glue. You could also use a food grade silicone, but remember to rough it up with some sand paper.
Feb 27, 2013 | Culligan Under Sink Water Filter
Have an under sink Culligan RO system with 4 potential filters but it only uses 3 (was so installed by Culligan). Filters are labeled - reading left to right Sediment SED10 ...
Pre-filter and carbon block filter are changed annually. The membrane is only changed every 3-7 years depending on water quality coming in, TDS and usage. Fourth filter is an in-line carbon filter that goes on the line up to the RO faucet.
RJH2O
Aug 12, 2011 | Culligan Compatible RO Prefilter AC30AC15...
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Culligan ac 30 reverse osmosis system - changed the filters, good flow for 3 days then began diminishing. Now nothing comes out of the faucet. Holding tank is empty.
I would pull out all the filters changed and check them. If a GAC filter is used as the post filter, before the RO tank, carbon fines can come out of the filter and can plug up the head on the RO system. Make sure the sediment pre-filter is not plugged and there is plenty of water supply. You may have lost pressure in the RO tank. A 3 gallon tank should have 7psi pressure when totally empty.
RJ
Jun 20, 2010 | Culligan Under Sink Water Filter
I need a water diagram for a culligan water system serial number is AC10001293
Here is a link to the Culligan website for the AC 30 owners manual. It has a breakdown view of the RO.
http://www.eculligan.com/support/ac30_owners_guide.PDF
This is about as close as you will get to a water diagram for the RO. The only place to find a flow diagram is in a service manual and those are well protected by Culligan.
RJ
Jun 19, 2010 | Culligan Under Sink Water Filter
How do I change the filer in my Culligan unit?
Turn the water off IN & OUT, (If this is a Culligan pre-filter it may have the shutoff valve on top), Press the red pressure relief button and hold it down for several seconds. Use the wrench provide and unscrew housing. Clean out the housing, lubricate the o-ring with silicone lube, replace filter and housing. Only tighten the housing by hand. Turn incoming water back on. It helps to hold the pressure relief button down after turning water back on to purge the air.
RJ
Apr 11, 2010 | Culligan Sediment Water Filter Heavy Duty
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
728 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
