Question about Nintendo Wii Console
Disc stuck My 8 year old thought she could use her ds game and now it is stuck in the cd section and it will not eject.
  • 26 Answers
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIYGuide. It also gives information on fixing many Wii Related Problems,so its a kind of Wii Problems Reference Fix Guide..
Posted on Feb 21, 2009
  • 52 Answers
The DS game is the small 1"x1" cartridge?
and its jammed in the disc slot.
This is a fragile, fragile part of the Wii. You could TRY a dentist pick with a hook end and get the game out that way. Don't force it, and stay straight in line with the disc slot and don't twist or turn it because you could damage it.
No guarantees if you will be able to perform this successfully, and this isn't a solution unless you're willing to chance destruction of your Wii.
-Good luck.
Posted on Feb 15, 2009
How do you get a stuck disc out of a ps4
  1. Step 1: Remove The Glossy Section of the Cover. Turn off the PS4. ...
  2. Step 2: Locate the Manual Eject Screw & Remove the Disc. With the glossy panel removed, you will see two sets of vents lining the outer left edge. ...
  3. Step 3: Put Everything Back Together.
Here How to Manually Eject Disc Stuck in Your PS4 PlayStation LifeStyle How to Manually Eject Disc On PS4
Jul 16, 2016 | PS4 Video Game Consoles & Games
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
My game wont eject
Okay, the same thing happened to me and I managed to get the disc out. First is the blue light on. If it isnt then you should hold the eject button and use another cd and push it into the disc drive and gently push your stuck disc around. When you hold the eject button your PS3 will make a loud clicking sound but dont worry. Just keep using the extra disc and push the stuck disc around and it should come out
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
My 2 year old son put a 2nd game in the Wii I did not realize this until I hit eject. The system was only turned on long enough to hit eject. But now it won't play any games just says to refer to manual....
With two discs in the system, it is more than likely that the discs are stuck. This would prevent the discs from spinning and it is possible that the discs are wedged. If you are handy, you could try to take the case off and remove the discs manually, otherwise I would advise taking it to a repiar shop.
Mar 08, 2010 | Nintendo Wii Console
Something stuck inside disc drive
try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Ds game stuck inside wii
lol funny situation now maybe you should get either 2 very thin peices of wire or something sort of solid and fish it out or unscrew your console and if there are wires hanging from bits just dont touch them and keep unscrewing and remember were you took the things out from then when you get to the cd slot take the ds card out and that should work good luck
Dec 27, 2008 | Nintendo Wii Console
System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Game stuck inside of PS3
hi you could try holding down the eject button for over 10 seconds, it rests the disc drive. hope this helps
Jan 22, 2008 | Sony Playstation 3 (PS3) Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
241 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
