RCA TV with Guide Plus that no longer receives guide at night
Have gone back through book redone everything it said. This is a 2001 TV. Would really like to get schedule of shows again as I don't take newspaper or TV guide!
    Sergeant:
  • 227 Answers
Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
Posted on Feb 15, 2009
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
Our tv used to have guide plus and now we con no longer get it. We have tried reprogramming and everything. please help.
yes! easy fix! unplug tv. wait 2 minutes. plug back in and turn on...... with factory tv remote, press....menu, 7, 1, go-back, tv...... then press menu, 7, 1, go-back, who-input. ............enjoy!!!!
Nov 10, 2009 | RCA Televison & Video
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
Not receiving guide plus + tv listing -no problem until 2 weeks
I called TimeWarner Cable tech support, and the solution is to unplug the power to the box, after 1 min plug back in, let the box reboot, and PRESTO, this time around, the guide should be working.
Note--this is a solution for the problem of online guide that is showing No Data in the boxes, but is bringing up the grid of times/channels/date.
If you can't get the Guide at all, I don't know if this solution works.
Good luck.
Dec 16, 2008 | Televison & Video
No channel line up in guide plus
Tune your TV to a Public Broadcasting Station before turning it off for the night. You should receive your line-up.
Oct 26, 2008 | RCA F32650 32" TV
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Oct 15, 2007 | RCA F25649 25" TV
Guide Plus feature not working.
hi call your service provider and tell all this they will fix it or send you a man good luck
Apr 28, 2006 | RCA F25649 25" TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
