Question about Kenmore 62802 Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
We bought a used Kenmore series 90 electric dryer and when we returned home we found it had a 3 prong plug. Our electric outlet requires a 4 promg plug. We purchased a 4 prong wire and found no indtructions on how to wire the 4 wire cord to the 3 recepticals on dryer. How is this done?
  • Anonymous Feb 25, 2009
    same as above only my kenmore 90 series needs a four prong to three prong conversion... how do I hook up the three prong cord to the back of this thing?
  • 5,911 Answers
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Feb 27, 2009
    Converting from a 4-prong back to a 3-prong is located under the Additional Notes section of the link I provided.
  • Jeff Rockwell
    Performing any kind of electrical maintenance (i.e., installing electrical outlets) should only be accomplished by a certified electrician. The easier option, and probablt least expensive, would be to replace the power cord. The average price is $10-$15.
  • Jeff Rockwell
    FYI: To clarify, here's the difference between between the two types of power cords:
    1. 4-prong - does NOT use a double ground. There are two HOT leads, a NEUTRAL and a single GROUND.
    2. 3-prong - has two HOT leads and a NEUTRAL (which gets grounded to the equipment chassis).
  • 686 Answers
You need to get a 3 prong outlet. 3wires on the dryer means 3 prong outlet. FYI 4 prong outlets and cords is for a double grond. Change your outlet to the 3 prong and your on your way Good Luck
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Start button not working
nope 4 prong is for mobile homes and 3 prong is for house. Maybe you wired the cord wrong.
Jan 05, 2014 | GE DPSE810EGWT Electric Dryer
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Jul 06, 2010 | Kenmore Dryers
Hook up a 4 prong plug in the back of a 3 prong series 90 dryer. What wire go to which screw?
white in the middle,red on one side black on the other just like the three prong and the green just has to be grounded to the back of the dryer,remove a screw close to the block as long as the wire reaches and connect the ground wire or green wire to the screw and screw it back in
Mar 20, 2010 | Kenmore Dryers
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
I have a 4 prong power cord coming out of my Kenmore dryer and I have a 3 prong power outlet in my wall. Can I replace the 4 prong cord with a 3 prong cord, and if so, how?
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
May 02, 2008 | Dryers
Kenmore 62802 Electric Dryer Logo
2,384 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
