Question about POSX POS-X WTP-150 Thermal Printer
Sewoo Model WTP-150 won't print or feed paper
We are on a POS system and this printer is only 3 years old. It appears that the paper will not feed anymore when you press the feed button and it won't print the customer receipts. When you put the paper in and close the cover and press the feed button, nothing happens and the error lights are on.
2 Suggested Answers
SOURCE: hi, I need a driver for the Sewoo WTP-150 to be
http://fernandomoralesdr.blogspot.com/ has the solution.
Posted on Oct 11, 2010
jaymahadev
  • 12 Answers
SOURCE: hi, I need a driver for the Sewoo WTP-100 thermal
CLICK HERE
http://www.woosimsystems.com/main/productDetail.aspx?prodID=45&catID=4&title=WTP-100%20II
Posted on Jan 24, 2011
Driver download
If you go to this website pos-x.com/EVO%20HiSpeed-p99.aspx you should find the driver link on the right of the page.
Oct 04, 2013 | POSX POS-X WTP-150 Thermal Printer
HAI I WANT THE DRIVER
Click on the link below to download the drivers for your Printer.
Download Link
Regards,
Sean
Jun 08, 2013 | POSX POS-X WTP-150 Thermal Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
I need to use the printer, just so the cash drawer will open. I don't have anymore paper to put in the printer, so i was wondering if there was anyway to turn the "need more paper" error noise...
If you have proper rights to the system you should be able to 'turn off' printing in the config menu. Refer to the User Manual for more info (i would tell you how but I honestly don't know)
Mar 24, 2011 | POSX POS-X WTP-150 Thermal Printer
Necesito el driver para wtp 150 para windows 7
http://fernandomoralesdr.blogspot.com/ tiene la direcci?n de la p?gina de Sewoo en ingl?s con los controladores.
May 06, 2010 | POSX POS-X WTP-150 Thermal Printer
My printer does not appear to be pulling paper through properly. The paper feeds, but the printing is starting imemdiately at the top of the sheet. Is this a spool problem adn can it be fixed?
Since your printer is more than 5 years old you can expect some wear on the pickup roller. A quick fix for your problem is to use alcohol and a toothbrush to scrub the gloss off of your primary pickup roller which is located in your paper feed drawer. These rollers tend to become glossy and smooth, which reduces your ability to feed paper into your printer.
Mar 14, 2010 | Lexmark X73 All-In-One InkJet Printer
Not feeding paper properly
if in australia contact Laserfast.Your printer pickup arm assy requires changing.
Jun 21, 2009 | Samsung CLP 300 Laser Printer
POSX POS-X WTP-150 Thermal Printer Logo
1,223 people viewed this question
Top POSX Office Equipment & Supplies Experts
k24674
Are you a POSX Office Equipment and Supply Expert? Answer questions, earn points and help others
