Question about 3d Rose Londons Times Funny Panel Hollywood Cartoons - Freezer Burns - Light Switch
1999 Nissan Sentra gxe is burning Oil?
I was wonderning what could cause my car to burn oil. it has a rebuilt engine with only 30,000miles on it, so if the fix isn't to expensive i would really like to keep the car.
    Problem Solver:
  • 17 Answers
The lovely smelling blue smoke is usually caused by oil getting into the cylinders due to faulty compression rings on the pistons. You'd be looking at a complete tear-down, not really worth it.
Posted on Mar 05, 2009
Oil leak 1998 nissan sentra gxe 1.6l changed value cover gasket seams to be coming out behind alternator.or lower.
Look for oil pressure sending unit. sometimes located on the side of the engine nearest the firewall. real pain to get to.
Mar 30, 2017 | 1998 Nissan Sentra
My nissan sentra 2004 model's engine runs out of oil in less than one week.
the only way you lose oil is by burning it or leaking it, if your car blows a lot of blue smoke, then you are burning it {engine rebuild or replace} if there is oil on the ground when you park, then you need to determine where the leak is coming from, pressure wash underneath before taking it to a mechanic, we hate getting under dripping dirty cars. glad to help.
Oct 22, 2013 | 2004 Nissan Sentra
Could a 2003 Nissan Sentra GXE with 84,500 miles on it have oil loss problems? My service engine light came on the other day and when I had it checked at Auto Zone they said it was my Catalytic Converter...
Catalytic converter works with emission gasses and had nada to to with oil consumption. People at Auto zone are
a-- holes and you should stay away from them.
May 08, 2017 | Nissan Sentra Cars & Trucks
1999 Nissan Sentra GXE Limited Edition, over 134k miles on it. Was driving down the freeway and hit a pothole, the engine started making a loud clanking/popping sound. As we pulled over, i took a look to...
It could be a broken Oil Pump, Is there oil in the engine or when you hit the pothole you could have hit the Exhaust Pipe and broke the pipe causing a Exhaust Leak.
Aug 18, 2010 | 1999 Nissan Sentra
Need to know 04 nissan sentra spec v valve flash sequence to fix tapping sound in engine
Not sure what you mean about a flash sequence. If there is a tapping noise,check your oil level and quality. When oil is low, the valve timing solenoid can not function properly as it runs on oil pressure. This will cause your tick noise. If your engine is burning oil the catalyst may be at fault. They break up and enter the engine through the exhaust valve and damage the cylinder.
Feb 13, 2010 | 2004 Nissan Sentra
Car is burning oil
you have sort of an swered your own question, its burning it slowly, it could be the piston rings have warn and the oil is seeping past them under presure and being burnt in the fuel, not not noticably enough to signs of smoke from rear , try checking the muffler/rear box and see if there is a sticky oily residue on it, for normal running it should be verry dark grey not pitch black and powdery, if its tacky and like tar, then you are burning oil. hope that helps
Feb 02, 2010 | 1996 Nissan Sentra
1999 Nissan Sentra GXE timing belt/chain maintenance
good day Sir, your nissan sentra 1999 gxe have a timing chain this is some tips for your routine maintenance.
Replace engine oil
Replace engine oil filter i
Oct 29, 2009 | 1999 Nissan Sentra
1999 nissan sentra gxe is burning oil?
If the motor is running good, try changing the pcv valve, as when they stop working properly, they can cause your motor to burn oil....
Feb 01, 2009 | 1999 Nissan Sentra
1999 Nissan Sentra oil in air filter
First off, nothing "blows" into the air filter. It would be getting sucked in from somewhere in your engine compartment. My guess would be leaking valve cover. Check around and feel for wet oil. That will also be a leak. Have you been going through more oil than usual? Check that also. Hope that helped.
Jan 04, 2009 | 1999 Nissan Sentra
1999 nissan sentra gxe headlight problem
I switched one of the new bulbs with a working older bulb, and the problem went away. weird...
Nov 09, 2008 | 1995 Nissan Sentra
3d Rose Londons Times Funny Panel Hollywood Cartoons - Freezer Burns - Light Switch Logo
220 people viewed this question
Top 3d Rose Electrical Supplies Experts
Ronald Prier
Craig Butler
Craig Butler
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
