Question about Microsoft Windows XP Professional
Boot system failure!
I wast just about to go on the mother inlaw's computer when it flashed up a message saying something along the line the lines of boot system faliure and stays on that message untill you reboot and then it does the same again.
I entered a windows XP disc to re install (this is what i was about to do before the problem showed up) It runs from the disc after going into the BIOS asnd begins to install the OS it goes through the windows setup system and after selecting formatt and re-partition it goes through the formatting section and file copying section perfect it then mentions something about setup will now reboot you pc and continue afterwards if there is anything in drive A please eject. it then reboots the system and then goes on to re install the OS. the only problem is it seems like it has forgotten you have already done the first part as it trys to prompt you to repair, format and reinstall OS
ANY IDEAS WELCOME. I know enough to get me by but this is the 2nd time i have formatted a pc and re installed an OS. the 1st with any problems!!!
  • 1 more comment
  • Ray Lang Feb 15, 2009
    thank you do i need to keep the disc in the cd drive?
    I would imagine yes?
    brilliant i will try this tomorrow
  • Ray Lang Feb 16, 2009
    ok i have gone back in to installing windows xp as jackie said i should reboot the system when prompted and the F2 and change it back to boot from hard drive this is ok apart from when it comes to loading where it finished from it says CD BOOT: MEMORY OVERFLOW ERROR
    Any ideas what this means?
  • 31 Answers
You need to start from the hard drive, or from hard drive with CD support. You can change the boot device priority in BIOS /change it so that the optical drive is not first but the drive you installed the OS is/, or in some boards there's the option to choose boot device. In case of a Gigabyte mobo it would be F12, that would bring a device list and after choosing your hdd the install would continue.
Posted on Feb 15, 2009
  • Jackie_T Feb 15, 2009
    Yes, it's still installing from the cd.
  • Jackie_T Feb 16, 2009
    That could be a hardware error, but lets check everything else first. Some people reported that error is caused by:
    1. dirty CD /finger prints/ - so lets clean the disc carefully.
    2. dirty reader - well the tray can be cleaned and a cleaning disc could clean the laser head for you
    3. usb devices - kinda odd and rare but for some if all usb devices were detached the install smoothly went on.
    4. formatting error - you need to go into fdisk /through a boot up floppy if ou have on or create a boot up disc in another system/ and check what partitions you have then format with fdisk /you should only have non hidden partitions/
    Also if you have both a CD drive & a DVD drive, make sure you are using the 1st physical device (according to physical hookup).
    Or try booting with CD in other drive.
    After checking all of the above you can try installing again and if you get the same error then it could be a hardware error /probably the hard drive/. If that happens install in a different drive and if it works there then you need to replace the hard drive where you cold not install.
    Do the install with as few peripheries as possible /only a moues and a keyboard, unplug everything else you don't need like speakers, memory cards or pen drives/.
    If you have more than one ram in it then take out all but one /smallest in first but/ and install. If you keep getting the error you can try switching them /both the memories and the slots/. This way you'll find the cause of the error /if it's one of the sticks or one of the slots/.
Unmountable boot volumn error with lines on screen
this may help. just watch the video and folow the directions. good luck.
Apr 11, 2013 | Dell Inspiron 8600 Notebook
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Toshiba portege r600 wont boot
Your BIOS settings may be wrong, or there may be a problem with the motherboard of the system.
I would check the BIOS settings on the laptop first.
When you first turn on the laptop - you might see something that says something like "Press F2 to enter Setup" or "Press Del to enter Bios" or "Press F1 to enter Setup" - or something along those lines. You will want to hit whichever key it is specifying and try to get into the BIOS/Setup.
Once you are in the BIOS, look for an option to restore defaults or reset factory settings. Do that and then save the changes and restart the computer.
If resetting the BIOS doesn't help, make sure that when you turn the computer on you are not plugged into a network cable at all.
If the system still gives the PXE error - then it is likely that something has gone wrong with your laptop motherboard. Unfortunately to get that fixed - you'll need to take it to a computer repair shop.
I hope that you can get the BIOS reset and it works for you though!
Nov 16, 2011 | Toshiba Computers & Internet
When i turn my laptop on it says (disk read error occurred ) then it say to press control alt delete to restart and i did and then this message came up agian so i plugged it into the charger did the same...
That error shows up when Windows find an irreversible error on the Hard Disk Drive. I'm sorry to say that the only solution is to change the Hard Disk Drive.
Jul 27, 2011 | Computers & Internet
I have a labtop x61 tablet which failed to boot the operating system windows vista
The best way to fix this is to insert the Windows Vista DVD that originally came with the computer. After you have the disc in, restart the computer and you should be prompted to "Press Any Key To Boot From Disc" or something along those lines...
Once you do that you will be given the option to repair Windows Vista. It will automatically scan the computer and fix any issues.
If you have a specific error message or have any trouble doing this, please let me know and I will be more then happy to further assist you!
Apr 23, 2009 | IBM ThinkPad X61 Tablet PC
Sysem will not remoot fast and properly
It sounds like you are having a hard drive failure.
The message your getting is not asking for the motherboard disk, it is asking for an operating system disk.
I don't understand how the computer ever get's to the Net if it can't get past asking for a system disk.
Please provide further information, such as operating system, how old the computer and hard drive are, and a more clear description of what the system is, or is not, doing.
Jan 20, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I recently removed and replaced the same hard drive in my laptop which is an HP Pavilion 4400. I booted it up today and I get a message that says there is no operating system detected. The computer will...
Sounds like you bought your new hard drive clean with no . You simply need to put in a boot disc, such as a windows XP installation disc for example, and go through and install the operating system. Look through your CDs you got with your laptop to find a disc with a windows operating system on it, for example Windows XP Home. It may say 'press any key to boot from disc...' along the line so just press any key and you will be on your way to setting up your new system
Hope This Helps
Nov 19, 2008 | HP Computers & Internet
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Dimension c521 computer gives a post error, floppy drive 0 error and keyboard error
The compute post tests the computer, insuring that it meets the necessary system requirements and that all hardware working properly before starting the remainder of the boot process.
1 Short Beep, Normal POST, computer is okay. No problem. 2 Short Beep, POST error....floppy drive 0 error and keyboard error........This can happen because there is something wrong with your floppy drive, something is causing your computer not to detect it or that you simply don't have one.
Check your floppy cables and connections first to ensure that they are connected properly, if they are then you may have a burned out controller on your motherboard, a bad floppy cable or drive, or your motherboard may be faulty. If you don't have one you can disable the message in your computers BIOS. To get to the BIOS screen, during boot up at the bottom of the screen it will say something like "press F2 for setup" or something along those lines. That will take you to the BIOS screen. In the settings there should be options like first boot device, second boot device, and so on... change the one that say 3.5 floppy to something else such as your CD rom.That will get rid of that message.
Keyboard error or no keyboard present shows up when your computer can't find your keyboard or there is something wrong with it. Replace with new keyboard. Thank you
Sep 06, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Microsoft Windows XP Professional Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
