Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Maytag MDB9600A does not drain well & is noisy
Also does not clean dishes well
It used to be so quiet you could barely hear it
  • 4 Answers
Try using a dishwasher cleaner, u can find it at walmart or your local supermarket. I found "dishwasher magic" is Wia good brand. U could also try several packets of lemon koolaid mix, the stuff in the small packets without the sugar in it. Run a complete cycle with the hottest water possible, and no other dishes in the washer. Make sure to read the directions on the bottle of dishwasher magic. hopefully these cleaners will clear out any deposits that are blocking your system. U might need two run a second cycle to clear out everything. If this does not work, and your washer still does not drain properly, your pump may be malfunctioning. Remember to make sure u load your washer correctly too. Which ever rack u put your plates on, make sure they are all vertical, and everything else on that rack should be loaded the same way. this will allow water to easily shoot thru to the second rack of your washer. u can load your second rack however, just make sure nothing will be hitting the water jet blade and prevent it from rotating.
Posted on Feb 22, 2009
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
Have a white film all over all my dishes and silverware
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Nov 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
My Maytag Dishwasher not cleaning the dishes. Doesn't seem to have enough water pressure.
clean the screen in the water control valve that is what the water line hooks up to or it may need to be replaced
Jun 09, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
The problem is hard water. has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 06, 2009 | Maytag MDB9600A Jetclean II Built-in...
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
My dishes are not clean and cloudy
After you have removed the filter and cleaned out any debris, clean the inside of the dishwasher with white vinegar by filling a bowl or large cup with white vinegar and placing it on the rack and running a short cycle with no powder inside.
Use a name brand powder (Cascade or Electrosol) rather than the ultra-cheap powder. Never use gel or tablets in any dishwasher.
If problems continue, you almost certainly have a failed heating element. Replacing the element yourself is not tremendously difficult if you are handy and promise fo disconnect the power before you begin. Otherwise, a service call is the next step.
Mar 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB6600AAW. Very Loud when washing, now door handle sticking
When the unit is running it is normal that it is a little more quiet. I think what your hearing is in the drain cycle for the first 30 seconds it is quieter than the next 60 seconds. The reason is in the first 30 seconds the water is leaving the machine and muffels the sound of the pump, for the next 60 seconds the pump is turning but the water is for the most part gone and the pump is sucking air which is louder and is normal.
Aug 20, 2008 | Maytag 24 in. MDB6600A Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
135 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
