Question about Ruud UBHC Air Conditioner
Ruud heating/ac unit blowing only cold air in heating mode
Ruud model# URGG-07N48JKR mfd in 03/89 is blowing only cold air when in heat mode. Is this a single phase heat pump? I changed t-stat (Hunter model# 44360) and believe I wired correctly. 4 wires:
1) T1 to T1
2) G to G
3) RH and RC jumpered together
4) W1 on old t-stat to W/B on new t-stat
Switches on back set to HP(believing I have a heat pump) and HG (fan works fine in HG)
Still only cold air blows when in heat mode. Any advice??
thank you!
  • 56 Answers
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Posted on Feb 16, 2009
Ruud heat pump is not heating.
You may have a problem with the reversing valve. How cold is your location? Do you also have electric back-up heat available in case of extreme temperatures?
Jan 29, 2014 | Ruud 2 Ton Split System Heat Pump
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
What size is my ruud gas pack
you have a 92' three ton unit in the mod # the 37 signifies 37000 btu, and the servial number states that it was made in the 44th week of 1992.
Feb 06, 2009 | Ruud UAMB Air Conditioner
Cool air through vents
I replaced the unit it was very old
Jan 25, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
553 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
