Question about Samsung MW1080STA Microwave Oven
Samsung MW 1080 STA mw1080sta Is there a way to mute the beep?
Does anybody know if there is a way to mute the beep on a Samsung Microwave model mw1080sta?
The beep is wayyyyyy too loud and wakes people up. Even my dog freaks out when it starts beeping.
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MW 1080 STA Weird displays when not in use
Your keypad or control panel are malfunctioning. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. You can order replacement parts here: http://www.samsungparts.com/search/search.asp If you or a friend decide to work on it, we have *critical* safety & disassembly, info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 24, 2007
What causes samsung microwave oven mw1080sta to blow fuse on switch on.
A dead short, probably in the step up transformer. Take it to a service technician.
Feb 13, 2018 | Samsung Microwave Ovens
Mute beeps
don't know if it's inherit or not to that model --you could check your manual and check with MFG on line or you could take a hammer to it---good luck
Dec 08, 2014 | Microwave Ovens
E41 and does not work
If your microwave is displaying an error code cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker.
If the above suggestion does not work,and the error code returns, your microwave will require service.
Aug 19, 2011 | Samsung MW1080STA Microwave Oven
We are using MW1080STA 1100w model in our lab. Can i adjust the the temperature(not power) in that according to my use like 40oc, 100oc 60oc. Please reply me urgent
The best method would be to use a food thermometer to measure the temperature of the food, and change the cooking time to get to the correct temperature.
May 12, 2011 | Samsung MW1080STA Microwave Oven
Cm 1929 error code e41
i there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Nov 08, 2010 | Samsung MW1080STA Microwave Oven
I have a samsung model mw1080sta serial # 75et301826r is that satinless steel?
try to stick a magnet to it ... stainless will not hold a refrig mag.
Oct 12, 2009 | Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Nov 10, 2008 | Samsung MW1080STA Microwave Oven
Apr 24, 2007 | Samsung MW1080STA Microwave Oven
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
Samsung MW1080STA Microwave Oven Logo
176 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
