Question about Whirlpool LER4634J Electric Dryer
Whirlpool LER4634PQ0 Shuts off after 5 minutes
Ny whirlool dryer LER4634PQ0 runs for about 5 minutes then shuts off. I cleaned the vents and the lint section. Problem still persists. Any suggestions?
  • jenafs May 11, 2010
    timed try
  • steve
    steve May 11, 2010
    Are you using timed dry or auto dry?
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
danromarris
  • 101 Answers
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
  • 98 Answers
SOURCE: Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Posted on Jun 07, 2009
woobie dog
  • 1273 Answers
SOURCE: My whirlpool duet electric dryer lets so much lint
Hi, You are correct in assuming that this can be dangerous.
It is not uncommon for some lint to "escape". The best ways to protect yourselves is to:
1. Install a metal duct hose from the dryer to the wall, if you have a plastic one. Metal resists better against fire. I would not have a plastic duct. Period.
2. Buy a dryer brush set (Lowe's/similar, ~$15) and use the brushes regularly. There are two in the set; one is a skinny brush and the other about the size of the diameter of the exhaust duct.
  • When you notice any build-up, use the brushes as best you can to keep it moving, and let it blow outside.
  • The larger diameter brush is good for cleaning your new, shiney, metal duct as well as the exhaust cavity of the dryer. (Always unplug the dryer before inserting the brush). The brushes can be used safely in the lint trap area, just don't insert tham any further than you can see them, unless you unplug your dryer. Set a schedule for cleaning your duct, and do it. I clean behind the dryer about every six months or so. More often if I'm missing socks! Clean your exhaust louvers regularly, too. They can stick and restrict flow.
  • Make sure that you eliminate as many kinks, bends and humps as possible in the vent duct from the dryer to the wall outlet. Every turn and bend just traps more debris. Sweep or vacuum behind the dryer regularly. Don't allow lint to build up.
  • The main aim of using the brushes is to get as much out as you can, and stir the remainder up so that it can pass on through to the outside harmlessly.
Best regards. I didn't mean to sound like Fire Marshall Bill.
I'm just W/D
Posted on Aug 10, 2009
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
Whirlpool elec dryer #LER4634PQ0 starts and heats fine and then shuts off after a few minutes. Will restart and dry the load. What is the prob?
might be a bad thermostat if cleaning the vent hose doesn't solve the problem. They're are usually 2 of them about the size of quarter, located on the heating element housing and easily replaced. I'm betting the problem is in the vent ducting!
Feb 10, 2015 | Whirlpool Dryers
Dryer runs for about 5 minutes then shuts off. It gets hot and drum rotates but it keeps shutting off. Then it takes about a half hour before it will start again.
It sounds like you're not getting good airflow and thus tripping the thermistor. Make sure all the vents are clear and the lint trap is clean.
Mar 07, 2011 | Roper REX5635E Dryer
My Whirlpool Dryer Model #LER5636KQ0 stops running after about 5 minutes. I have checked the lint screen and lines all the way out of the house, there is no lint build up. I even let it run without the...
If you are absolutely sure that the vent is perfectly clear, then the device that shuts off unit due to overheating is going off prematurely. Go to attached site for part involved and get a new one. Search Over 2 1 Million Appliance Parts
Aug 27, 2017 | Whirlpool LER5636P Electric Dryer
Whirlpool LER7646JQO Electric Dryer turns on, drum turning, runs for 3 to 5 minutes then clicks and shuts off. Smells like it is burning. No kink in hose vent or lint clogs.
Most dryers have more than one thermostat.
Most likely, the operating thermostat has failed, but the high limit thermostat is working and turns off the machine when it gets too hot. When it cools down it will start again and run briefly. If the high limit thermostat fails, the thermal fuse will permanently stop the dryer to prevent a fire.
Apr 07, 2010 | Whirlpool Dryers
My whirlpool dryer keeps shutting off
make sure the vent pipe (and the lint trap) is clear and not plugged with lint
Aug 24, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
215 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
