Question about GE Spacemaker JVM1640SJ Microwave Oven
Burned out after 2 years
My GE microwave zmc1095sf03 burned I mean flames where coming out of the bottom. It seemed to me that a small wire was the problem, but of course GE said they would replace it with a super cheap model at 1/2 the price. How disappointing!
  • GE Master
  • 5,568 Answers
This may not help your spirit much, but it appears you are not alone:
GE Complaints
And, I would refrain from buying any other GE anythings since they are trying to dump their entire consumer products (appliances) division. I don't doubt some schlock Asian outfit like Funai will be willing to milk the name for a few years and build still more crappy products.
What a pity, still another formerly great American company.
Posted on Feb 15, 2009
We have a GE profile microwave with inverter tech that will come on for about 5 seconds then shut off. Unplug it and plug it back in it does the same thing. It lets off a terrible smell almost like a...
Remove vent grille, then remove control panel. Check wire to cavity thermostat. Sometime wire bundle and small space causes poor terminal connections on this thermostat and will burn wire terminal. Cut off bad part of the wire, install a small terminal end, reconnect to thermostat. If thermostat is destroyed, also replace thermostat.
Aug 13, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
When using on small amounts of food would burn (spark & flame)
Sparks in microwaves are caused by metal things in there. What kind of plate - any metal or gold leaf decoration on it?
Try a microwave safe dish.
Make sure you do not use metal items in microwaves.
I do not know the model number of your nuker, is it a new one or old? How long have you had it, and has it always done this?
Apr 26, 2009 | GE Microwave Ovens
GE Microwave dead
Chances are the flames opened the oven cavity TCO, which acts as a flame sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (cavity TCO) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 31, 2009 | GE JVM2070 Microwave Oven
Burned inside of microwave
This is the the stirrer cover, and it provides important protection for the magnetron and must be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 15, 2009 | GE JEM31 Microwave Oven
R-A795 microwave
just how old is that unit
replace that microwave
power source popped
DIY repair may result in a fire
Apr 28, 2017 | Sharp R-7A95 Microwave Oven
GE Monogram Microwave
GE, couldn't even find the model number. They pretty much, in a nice way, told me I was out of luck, it would be $149. for them to tell me why it's not heating. If it's the magnatron tube, they'll cover the PART ONLY!!
I took in to ABT, where it was purchased, it's now, three days later, they still haven't called to let me know what the problem is and how much it will cost to repair.
I purchased a Panasonic oven for $79. and am making do for now.
Thanks.
Nov 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
91 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
