Question about Traulsen Freezer G22013 Freezer, Reach-in, Two-Section
Freezer wont cool
I have a Traulsen Freezer G22013 Freezer and it is running the compressor starts up but won't cool, could it be out of freon?
  • 51 Answers
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Posted on Feb 17, 2009
My traulsen refrigerator is warm not cold
the pump unit is burn
or you have a leakage on the cooling fluid !!
all your dealer and ask the sometime the answer those question with no charge $$ !
Apr 05, 2015 | Traulsen RDT332NUT-FHS Reach In...
Freezer temperature keeps climbing thawing out the food.
Check the thermostat, and the cooling fluid.
Tao the thermostat en see if it will start the compressor. When you hear the compressor running and still no cooling, you must have lost the cooling fluid. (used to be freon)
Mar 07, 2015 | Samsung Freezers
Not pulling down to temperture
The most common problem is low refrigerant (freon). If you don't have gauges to check the pressure of your refrigerant, do this: the compressor has one small line running to the coils on the top of the freezer. That small line should be hot enough to burn your finger if you touch it when the compressor is running. Also the big copper tube running into the compressor should be cold to the touch, almost freezing. If not you are probably low on refrigerant. Without gauges and the ability to buy freon, you will need to hire a refrigeration repair service to find the leak in your system, repair it and then gas it up. But there are a couple of other things to check first. Near the compressor is a radiator like set of coils in front of a fan. If the compressor is running that fan should be running too. if not, the unit won't cool. Also the radiator coils may be covered with dust or grease. You must have a good flow of air through these coils to dissapate the heat put out by the compressor.If it is stopped up, brush the dust from the front of the coils. Look inside the freezer as well and make sure the inside coils are not frozen over. Is so unplug the unit and let the frost melt off. If that is happening you may need a new timer on your drfrost system.
Oct 08, 2010 | Traulsen 69.1 cu. ft. / 1957 liter...
Freezer Unit Isn't Functioning
Inside the refrigeration system alot is goning on. You have to check the pressures low/high to determine the problem. It is easy to say that your unit needs freon but that is not always the case.
here is a list of possible problems:
dirty condenser
dirty evapoator
fans not working
defrost not working
lost of freon
bad compressor
bad compressor valves
slugging
flooding
lack of oil
super heat off
txv is stuck open/close not sensing
incompatilbe unknown freon mix...
well these are just some of the problems you can encounter. this was meant to tell not fix because each problem needs attention but hope this was a little helpful anyways
Mar 29, 2010 | Traulsen 69.1 cu. ft. / 1957 liter...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen 2 door freezer
Traulsen Freezer Compressor Change Out Video
Dec 05, 2007 | Freezers
Traulsen freezer urns for about 2 weeks then stops getting cold enough
Will it restart again? How old is this freezer? Could be start relay loose or a burned wire connection, worn out compressor. Let us Know what you find
Oct 12, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Freezers Logo
206 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
