Question about Kenmore Elite 45986 Front Load Washer
Spots on my clothes
I get spots on my clothes. It looks like grease spots. What's going on?
  • 77 Answers
Hi, your drum bearing needs replacing, hope this helps, thanks for using fixya
Posted on Feb 15, 2009
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
Clothes comes out with spots. looks like grease spots.
the valve is lose or better still u hot wash it 4 10 -20 minutes then u spin and check it again with old clothes, then if it continues the valve is lose some where in the washer
Jul 06, 2011 | Kenmore Elite 45986 Front Load Washer
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Greesey Spots.........
looks like the grease would be coming from the shaft at the middle of the tub. that would be the only source of grease in that area.you need to remove the whole drum to look at it.
Feb 19, 2008 | Washing Machines
SPOTS ON WHITE CLOTHES
if your washer has a slight rumble noise when on the spin then it is most likely that your bearings are on there way out,what it is is the bearings have grease in them and once the bearings start to go this grease starts to leak into the drum which is what the brown spots are it also leaks at the back around the bearing at the back of your outer drum and also leaks onto the floor this will need fixing by a domestic appliance engineer but it is sometimes cheaper to replace the washing machine
Oct 17, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
229 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
