Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2100 bag light stays on and power won't cut on
What could the problem be?full bag indicator on with new bag. Power shuts off.
    Scholar:
  • 75 Answers
The problrm that you are facing is in all probability being cause by a faulty vacum sensor... now for replacing the vaccum sensor i'd suggest you go for a service technician but in the meanwhile I could let you in on a procedure by which you could make that light go away till you get the faulty sensor fixed..
f you want to open the machine, the two bumpers on either side, that say ELECTROUX (or have a model name) hold the egg shell together. This is the process....
1. remove the bag, leave the bag cover open
2. lay the vacuum on its side on the floor with the bag cover to your right hand side.
3. place screw driver blade flat against the bumper on the opposite end from the bag cover, near the cordwinder cover, strike the screw driver firmly with a hammer, this will unlock the bumper and it will slide off toward the bag end of the machine.
4. turn the vacuum onto the other side, and follow the same process.
5. after both bumpers are removed you can get into the vacuum.
At the vaccum sensor there will be two yubes one going to the canister n the other to the power swithc... just disconnect the one going to the power switch n seal the sheath back up. The light will not go on again till you connect the hose back.
This is a tricky procedure n if you are not relatively tech saavy (n brave for that matter :-) ) you'd be better off getting a technician coming n replacing the faulty vaccum sensor.
Posted on Feb 15, 2009
    Sergeant:
  • 326 Answers
Keep it off for some time then on it and also check out the motor is it getting blocked by something internally.
    Sergeant:
  • 250 Answers
Take the hose off and check it will be clogged very tight. There will also be a piece of a 3 inch wire got stuck in there make it proper again.
If you open the cover and remove the bag you will see a plastic lever (actuator) in the upper left corner of the bag compartment. If the bag is not properly positioned over the lever, or if the cardboard portion of the bag has been damaged or wrinkled it will not cover the lever. Reposition the bag or replace it with a new one.
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
127 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
