Question about Kenmore Refrigerators
Fridge making a loud noise like an electric engraver
Makes this sound every 2-4 minutes also the freezer is thawing
  • momomkelly Feb 19, 2009
    We did end up having a guy come out. He told us that the compressor was bad and that it wasn't worth it for us to have it repaired. So, it is gone and replaced. Thanks for your quick response. I have to say I initially had hoped that you were wrong!
    But you were right on!
  • 121 Answers
It is compressor bad,plug cable from wall and after 2 h try again if want work compresor is bad,call service.
Posted on Feb 15, 2009
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
