Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE RANGE WONT STOP BEEPING EVEN WHEN IT IS UNPLUGGED
Beeps about every 15 seconds even though it is unplugged !!!
  • GE Master
  • 3,361 Answers
Replace the electronic control.
Posted on Feb 21, 2009
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Beeping sound on ge profle refrigeratioree
if the temperature is above 44 degrees that alarm will keep beeping
Apr 22, 2014 | GE Profile PSW26P Stainless Steel Side by...
03 Buick Regal wont stop beeping, now my car wont start! HELP!
Ok, first off do you have a chiped key? look on the side for a resistor symbl if yes try a spare key if you have one. secondly is the theft light flashing? third option turn the key to the on position wait 15 and try to start the car, if it is your security system this will sometimes deactivate it
Apr 30, 2013 | 2003 Buick Regal
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Microwave is beeping even though everything has been cancelled. We already tried unplugging to reset....still beeps.
Chances are you have a shorting membrane keypad. It's very common.
Ever had the F3 error?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It keeps beeping and I can't get it to stop I've even tried to unplug it and it still beeps
Press the status button and it will tell you what the trouble is, then you can determine the solution. - Alarm Professor.net
Aug 05, 2010 | GE Security Simon 3 Wireless Home Security...
Beeping & flashing F7
It means one of the keys is stuck or shorted. Shorted Clear/Off Key
due to membrane switch,
Control or connector
May 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
GE Profile XL44 beeps erratically!
You have a bad key pad. The main control (ERC) thinks you are pressing a button. It is possible (although remotely) that the ERC may be bad instead... I give it 95% chance bad keypad and 5% chance bad ERC
Nov 28, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
259 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
