Question about Microsoft Zune JS8-00001 Digital Media Player
I need battery
I need a new zune 30 battery .my zune keep going off
  • 38 Answers
You sure it's the battery?
Try this.
Or this.
Or go here.
And here.
It's amazing what one can find on the WWW when one takes a chance and does a wee bit of work.
Posted on Mar 08, 2009
How can i update zune hd
How to update your Zune player
Overview
If you haven't used your Zune player in a while, you might need to update it in order to get the latest features and improvements.
Steps to update
  1. On your computer, start the Zune software.
  2. Connect your Zune player to your computer by using the USB cable that was included with your player.
  3. If a newer version of the Zune firmware is available, you'll see a notice to update your player. You can also manually check for new player updates in the Zune software. Go to Settings (located at the top of the screen), Device (located in the upper-left corner), and then Update (located in the list at the left).
  4. If you receive a notice to update your player, follow the on-screen instructions. Important During the update process, don't disconnect your Zune player it until the update finishes. The update might take several minutes. During this time, your Zune player might restart several times.
Mar 31, 2015 | Microsoft Zune 30 Gb Digital Media Player...
Zune player hardware problem
eeh, this is a pretty bad problem. I would ask you if you had a warranty, but you took it apart... I can only suggest getting a new one, not a 30 GB because that one seems to have the most problems. Fixing it though, you could ask the Geek Squad about it. Next time it freezes, just wait for the battery to die, then charge it and restart it.
Jan 20, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune freezes and says contact support
in order to fix this . you have to restart the device. to restart the device you press and hold back while also pressing and holding the top part of the zune pad until screen goes blank and zune logo appears this should work. if contact support comes back up try restoreing the device.
for more info on how to restore the zune go to zune.net/support and press technical issues and a list with how to fix any problems will appear
Jan 09, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune locked
Go look on zune.net and then click support. My zune just did the same thing a little bit earlier and I was worried so I went looking on the net and found these entries. Under support it says:
My Zune 30 is frozen on the boot screen, now what do I do?
You will need to reboot your device after noon GMT (that's 7 a.m. Eastern or 4 a.m. Pacific time) on Jan 1, 2009.
Please unplug your Zune (no AC or USB cables).
Because your Zune is frozen your device battery will begin draining, this is good.
The battery will eventually be fully depleted and the screen will go black.
After noon GMT on January 1 connect your AC power or USB cable such that the battery can begin charging again.
Once the Zune has enough battery to boot it should do so normally and you can go back to enjoying your Zune!
My Zune 30 has been working fine today, should I be worried?
Nope, your device is fine and will continue to work as long as you do not plug it into the PC before tomorrow.
If you plug your device into a PC before noon GMT Jan 1, 2009 your device clock will be set to the last day of the leap year and you will experience the freeze issue. If this happens, see above.
The PC that you plug into does not have to have the Zune software installed in order for your device clock to be set and the leap year bug to occur so you should avoid plugging your Zune 30 into any PC today.
What if I have DRM content on my Zune?
Your DRM content will most likely not be affected by this issue. However, it is a good idea to sync your device with your PC once the freeze has been resolved in order to ensure that all of your licenses are up to date.
What if I took the advice on the forums and hard reset my device by disconnecting the battery?
This is not a good idea and we do not recommend opening your device up yourself. However, if you already did it…
If you have DRM content on your device, your DRM store is now out of sync with your secure clock.
You will need to wait 24 hours from the time that you reset the device and then resync your DRM licenses from your PC.
Alternatively you can format your device and resync the content.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Zune 30 G
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 23, 2008 | Microsoft Zune JS8-00001 Digital Media...
30 gb zune can't get into program
May 07, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
22 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
