Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Vaccuum Won't Stay On
When I press the start button the vacuum used to stay on, however now I have to hold the start button down. Does anybody have a solution to this?
  • llamprecht Mar 24, 2009
    Our Bissell Healthy Home Vacuum just started doing this: I can push the button and it turns on but if I take my finger off of it it turns off again. HELP!
Two ways to go about this:
Easy Way
1) Go to Bissell.com and order the replacement handle for about $25 bucks. Follow installation instructions and viola! You're up and running again.
More Complicated (you're on your own)
2) I'm no expect by any measure. I just tinkered around and here is what I got.
  • Remove the handle (If you remember when you purchased the vacuum, you had to install the upper handle by connecting it midway and tightening it with a Philips screw).
  • I shouldn't have to say disconnect the power, but yeah, that's probably a good idea too.
  • Remove all screws in the handle. Keep note of which screws came from what area, mine were different sizes.
  • Split the casing open and remove the red plastic cover. You will find a small switch underneath
  • I just fiddled around with the small switch until it worked again; you can also go online and buy a new switch Click here for the switch only
  • Once you have the switch working, or purchased and installed a new one, put the handle back together and install again to the vacuum. You may want to test the switch before completely installing the handle. You can do this by connecting it without tightening the Philips screw in the middle.
Hope that helps a little. I know my wife was disappointed until I got ours up and running again.
Cheers
Posted on May 16, 2009
Dyson dc35 button won't stay on
Where can I order the switch from?
May 19, 2012 | Dyson DC35 Handheld Vacuum
Vacuum will not stay on
Hi Patriccia,
I'm sorry to hear you're having difficulties with your Dyson's on/off switch. If the switch won't stay down when pressed, please call us free on 1866MYDYSON, or email askdysonUS@dyson.com so we can provide further assistance. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Nov 13, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
Quick Fix...takes 4 minutes max
Remove the switch by using instructions here:
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
(The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
On button won't stay depressed. when pushed to on, the vaccuum goes on but won't stay on unless button is held down.
Needs a new on/off switch. You can order one from an appliance parts store, and replace it yourself or take it to a shop.
Charlie
Feb 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Dyson start button will not stay on. I have to
those switches go bad all the time. replace the switch and it will be fine. let me know if you need the switch
Jan 03, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
255 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
