Question about Honeywell Programmable Thermostat Heater
Premature thermostat battery failure, possibly due to corrosion
I installed 3 new Duracell Alkaline batteries in my Honeywell Programmable Thermostat on December 11, 2008. (The package the batteries came in indicated that they were best if used by 2015.) On February 10, 2009, the thermostat started flashing ''Replace Batteries.'' The batteries should not have to be replaced more than once a year. I called Honeywell customer support, and the technician told me that the area where the batteries touch the metal in the thermostat could be corroded so I should purchase electrical contact cleaner from Radio Shack. I tried to look at the area, and there appeared to be a slight discoloration where the batteries touched the metal although I couldn't tell for sure. I went to Radio Shack and purchased a 5.5 ounce can of Radio Shack Precision Electronics Cleaner for $ll.65 (including tax) which I can return if I don't use. Among the uses listed on the Cleaner can is battery contacts. (I will never use the Cleaner again for anything.) Instead of using the expensive Cleaner, can I safely apply rubbing alcohol on a Q-tip to the possibly corroded metal area where the battery touches? Would this fix any corrosion problem, and would the rubbing alcohol be safe to use and not damage the metal? If I should not use the rubbing alcohol, should I use the Radio Shack Precision Electronics Cleaner? Are there any special tips/warnings for applying the Radio Shack Cleaner? For example, although the Cleaner instructions say to spray directly on the area to be cleaned, should I instead spray the Cleaner on a Q-Tip and rub the wet Q-Tip on the metal area to limit the possibility of getting excess Cleaner on the Thermostat?
  • Marilyn Martin Feb 17, 2009
    I agree that I probably should return the expensive Cleaner. However, I still need to clean the battery contact corrosion. What can I use to clean the battery contact corrosion that would be both safe and effective? The suggestion to change the batteries once a year regardless of whether or not I get a "Replace Battery" signal is a good one. I will do that in the future to prevent corrosion.
  • 56 Answers
I would not spend the money on the contact cleaner for one. i would just change the batteries once a year regardless of being good or bad. It is a practice I use in my own home thermostat. As with anything these days just because they are new does not mean they will last for a long period of time. Hope this helps and I would return the cleaner. If by chance you put the new batteries in and it happens again you may have a faulty battery sensor on the thermostat.
Posted on Feb 16, 2009
Thermostat changed to Celsius without out us changing it. We have had this thermostat for several years without any problems. Reviewed the manual and checked to see if the original install was set...
Check the dip switch (3) it should be in the on position...It may have moved when you mounted the thermostat on the base. Also check batteries you are using...long life alkaline only.
Feb 25, 2015 | Honeywell CT3200 5-2 Day Electronic...
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
What does it mean when the battery error message stay on.replaced batteries, should. I purchase a new thermostat
No friend,
Inside the Honeywell box WILL be a battery. which is there to keep your settings if a Power Failure occurs.
All you have to do is change it and reset your Control.
A typical change of battery is explained here.
http://homeguides.sfgate.com/change-wall-thermostat-battery-25307.html
Sep 13, 2014 | Honeywell Programmable Thermostat Heater
What type of batteries are needed for the Honeywell thermostat model RTH2310?
Two AA or LR6 batteries alkaline type (Duracell for example).
Mar 30, 2014 | Heating & Cooling
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
May 09, 2011 | Honeywell Programmable Thermostat Heater
What can I do to fix my Honeywell thermostat -- I didn't turn it off before changing batteries and now it won't work at all
Hello
If the thermostat will not turn on and it has good batteries as back up to wall DC voltage then the conclusion is that the Thermostat has failed, these are considered throw away and are not serviced by Honeywell except under warranty and then they send out a new one and "thrash" the old one, so fixing it is not an option, you will need to just replace it, a good quality electronic programmable T-stat is less than $40.00.
Oct 29, 2010 | Honeywell Programmable Thermostat Heater
Everytime i replace the battery in my thermostat it says low battery
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 22, 2010 | Honeywell Programmable Thermostat Heater
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
843 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
