Question about Canon DC210 DVD Camcorder
Transfer to dvd
I just want to transfer what was recorded from the disk you put into the Canon dc210 to a regular dvd so that i can view what i recorded on a dvd player.
    Scholar:
  • 135 Answers
The disk from your cam should play on any standard dvd player.
The size of the disk is irrelevant.
You may even notice a smaller circle in the tray of your dvd player but even if you can't, it should still play.
Best wishes.
Posted on Mar 03, 2009
Initialize the discs then record...but then it still wont play on the computer/dvd player Canon camcorder dc210
I have a Samsung recorder, and it requires you to "finalize" the disc before it will play on another unit. Check your manual for specifics, or look in your menu for the "finalize disk" option. Hope this helps...
Mar 14, 2010 | Canon DC210 DVD Camcorder
I want the pictures and video off my DVD-RW on to my computer
Yes, you must finalize to view the dvd in a stand-alone dvd player.
No, battery doesn't have to be charged but the camera does have to be plugged in to do finalizing.
After, finalizing the disk, and you are in fact using DVD-RW (re-writable) disks, yes you can un-finalize them within the Canon camera to record more video.
I have used the same 3 rewritable disks on my Canon over and over again to record many hours of footage.
Apr 30, 2009 | Canon DC210 DVD Camcorder
How does one transfer the video or 'still pictures' from Canon DC210 Camcorder onto their PC?
All you should have to do is finalize the disc. Put it in your DVD drive and select the scenes and photos. you need to have DVD playback software to play the disc also if its a DUAL layer disc you have to make sure the drive in your PC can play DL.
Enjoy,
Lee
Jun 04, 2008 | Canon DC210 DVD Camcorder
CANON DC210 CAMCORDER DRIVER CD LOST
I HAVE LOST MY INSTALLATION DISK FOR MY CANON DVD CAMCORDER DC210...CAN U HELP ME IN FINDING AND INSTALLING THE SOFTWARE FOR THIS CAMCORDER SO THAT I CAN SEE MY RECORDINGS ON MY COMPUTER
May 04, 2008 | Canon DC210 DVD Camcorder
Dvd to prints
You can either
1. Transfer the still pictures from the camcorder to the PC, and then, either
1.1 use your PC software to print the pictures, or
1.2 use an online photo processing lab to print the pictures for you.
OR
2. Take the disc from the camcorder to a local photo printing shop and ask them to print the pictures you want printed.
But first ...
before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You also need to make sure that the DVD drive on your PC is capable of reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk formats that the DC210 will handle. Not all PC DVD drives can read these formats.
To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then, switch on the camera, put it into playback mode, Press 'Func.', select main menu, select 'disk operations', select 'finalise'. Don't move or shake the camera or switch it off whilst the finalising step is underway - this could cause problems.
Once finalising is complete, take it out of the camcorder and then follow steps 1.1, 1.2 or 2 above.
Good Luck.
Apr 11, 2008 | Canon DC210 DVD Camcorder
How to copy from CANON DC210 DVD Camcorder to PC
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
Once finalising is complete, put the disk into the PC.
Good Luck.
Apr 03, 2008 | Canon DC210 DVD Camcorder
Will not play on computer
Good Luck.
Mar 25, 2008 | Canon DC210 DVD Camcorder
Transfering from canon dc210 to my pc
Good Luck.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Transfer from my canon dc210 to my pc
If you can play the DVD disc on your computer you will be able to transfer footage and edit it.
Put the DVD disc into your PC's DVD drive, then
1. Select 'start'
2.
Select 'My Computer'
3.
Find your PC's DVD drive in the display of devices shown, right click on it, then left click on 'Explore' in the drop down list.
4. Copy all the files you see shown with the 'Explore' option to a folder on your hard drive.
You can now use the software you normally use to edit the files you've just transfered to your hard drive.
Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
Oct 18, 2007 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
79 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
