Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Oven will not preheat properly
Model w30400b single oven, when i preheat oven to 350 it only indicates 100 degrees. i can hear a whining noise in the circut board behind the interface on the side of the wall. after 45 minutes it will begin to preheat to my desired tempature. what is my problem?
    Problem Solver:
  • 14 Answers
Possible thermostat is sticking
Posted on Feb 15, 2009
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire stove with oven
I have the same problem. Any resolutions for you?
May 08, 2008 | Frigidaire FEB30S5D Electric Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
475 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
