Question about GE DBSR453EBWW Electric Dryer
Dryer will not start
After changing my heating elements for my ge dryer, i put it back together and now it will not start.
    Problem Solver:
  • 14 Answers
DOOR INTERLOCK
Posted on Feb 15, 2009
  • teddymorris Feb 15, 2009
    INCORRECT WIRING
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
Apr 21, 2010 | GE DVLR223 Dryers
I just recently took apart my GE Dryer, model number DJSR473ET1WW to fix a loud noise. I put it back together and now I realize that the back of my dryer is extremely hot. Is there something I may have...
Sounds like you hava a venting problem. Disconnect the vent on the back and see if it still gets hot.
If it gets hot when the dryer is not on, then the heating element coil is shorting out on the element pan.
Hope that all helps.
Jan 15, 2010 | Washing Machines
Dryer will turn on and spin but is not heating up
This usually means the heating element (wire inside behind the turning drum) is broken. Unplug the dryer. Open up the back and front of the dryer, remove the drum's belt, then the drum. You should see the heating wire at the back. Check for the break. Then using pliers, join the two broken ends together by twisting the wires together. Put the parts back together, plug the dryer back in and away you go.
Aug 06, 2009 | Dryers
GE Adora Dryer spins but no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Aug 05, 2009 | GE WSXH208A Front Load Washer
Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Feb 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
Getting into a ge harmony dryer seen some posts on it not heating up cannot get to element to check it model #dpgt750ec1ps
taking everything out though the front my breaker was bad not getting both legs of my 220 after I put it all back together I trip the high temp thermister and had to take it all back apart to reset it so do not run your element without air over it for to long.
Nov 29, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Hotpoint Dryer NVLR333ET0WB
ck for thermal fuse on outer edge of element housing it usually a small round disc
Jul 23, 2008 | Kenmore Elite HE4 Electric Dryer
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
60 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
