Question about DFI CA64-TC Via 694T/686B Mainboard (MBDFICA64TC) Motherboard
I need the 686 bios
Hi sir i have a 686series motherboard.sir i need the bios of this board that how can i use this board?
  • 1,602 Answers
GO TO THE VENDOR, USED COMPUTER SHOP, 2ND HAND STORE, EBAY.
EBAY MAYBE YOUR FASTIST WAY AND FINDING SOME HELP WITH YOUR PROBLEMS TO AND HELP YOU RESOLVE IT
OR
REPROGRAM THE BIOS
AND OR OPTIONS
UPGRADING BIOS
WWW.ALLELEC.COM
WWW.MIKE@TTITECH.COM
WWW.UNICORE.COM
SOME EPROM PROGRAMMERS
ROD
Posted on Feb 17, 2009
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
Tip
Sir i need 686 bios chip. if u have so that plz tell me in my this number....
my ga6wmm7 rev 1.5 boot order adjestment on bios not work only from flopy what can i do to boot from cdrom or hd? thank u
on Feb 15, 2009 | Gigabyte GA-6WMM7 Motherboard
I need motherboard driver and setup spec for VER:5. The board does not boot to BIOS or provide video via AGP or PCI. BIOS chip label stamped BK40 3457 (686 AMIBIOS). I DO NOT KNOW HOW TO CONFIGURE THIS...
Simple test: disconnect all disks, remove the BIOS battery for 10 minutes, put it back (this resets everything to default factory settings) then try to boot in the BIOS - if it fails then the motherboard is defective - no BIOS update can fix that.
The board is dead, time for a new pc.
May 02, 2011 | Computers & Internet
HI, I encounter some problem when I start my computer. An error message appears "BIOS ROM Checksum error3 I think there is a problem with the bios in my motherboard. The ref for the Bios is : Phoenix...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup. If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date. Save, Exit and re-boot and everything should then work.
hope this helps
Dec 16, 2010 | Computers & Internet
I have a Award 1998 PCI/PNP 686 bios chip and need to be able to use hard drives 80 MB and over. Is it possible to replace the chip or can it be reprogrammed? I had used a Maxtor Ultra 200 V2.01 bios board...
Since Award 1998PCI/PNP 686 bios chip needs 80MB and over.. My suggestion is to buy a higher capacity drive to be able to support the boards requirements.. just post again for more questions.. thanks.. =)
Oct 08, 2009 | Intel D850MV Motherboard
Bios file
SOLTEK has gone bankrupt -- their web-site is "down".
So, there is _NO_ support (BIOS-update, drivers, replacement parts) available at all.
May 18, 2009 | Soltek SL-K8M800I-RL Motherboard
Award BootBlock V1.0
Hi.
The BIOS (Basic Input output System) on your motherboard has become corrupted and the computer can't boot normally. The Bootblock is a "failsafe" device that allows the computer to boot far enough to use the floppy disk drive, even though the rest of the BIOS code is scrambled.
How do you think this happened? The most common cause is people trying to "update" the BIOS and messing up the flashing process. Sometimes some particularly nasty viruses can wreck the BIOS code as well.
Now this might be fixable. You will need to download a known good BIOS from Iwill's website and the Award BIOS flashing utility. Then you will need a bootable floppy disk (DOS) to start the computer. You will have to copy the BIOS .BIN file over to the floppy beforehand and the flashing utility. There will be information on the Iwill website on how to flash the BIOS.
Here is a full detailed webpage on how to go about all this:
http://pages.sbcglobal.net/jefn/bootblock.html
I just did a quick Google search using the motherboard details you provided and came up blank ....
If you can't get the BIOS flashed and usable again then I'm afraid it's time for a new motherboard/computer.
Dec 30, 2008 | FIC AZ 31 Motherboard
On-Board USB Problem
try to download and install a USB driver or came with your motherboards cd it has a usb driver too. hope that helps!
CHARCOIS
Aug 23, 2008 | VIA P4MA Motherboard
Motherboard and BIOS problems
hello
good morng
th m.b is pasword lock
Jun 04, 2008 | Intel Motherboard
Issues in Upgrading BIOS
Actually, your motherboard is a GA-7ZMMH, which we were lucky enough to see in the BIOS ID string. You can find the latest BIOS's from Gigabyte's website at: http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1315 It looks like you're on the F5 rev. I would suggest the F10 rev, and only go to the F11b rev if you need the support for the Athlon XP 2600+. If you are not upgrading your BIOS for CPU support, or you do not need to support a CPU faster than the Athlon XP 2200+, then go with the F10 rev.
Sep 03, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
DFI CA64-TC Via 694T/686B Mainboard (MBDFICA64TC) Motherboard Logo
157 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
