Question about Ovens
Electronic control panel for stove made alot of noise then quit
Lock on stove has been going on without being set for a few months. today the panel started blinking and amking noises then stopped. we unplugges the stove and plugged it back it but it now reads dr in the clock area and has the lock light on but does notthing else
    Problem Solver:
  • 14 Answers
RE TIMER
Posted on Feb 15, 2009
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
My older model Frigidaire oven door won't open.
Hello friend, thanks for your post!
From what you are describing it sounds like a possible issue with your control panel or door assembly. I would suggest a reset to your appliance which you can do by disconnecting the power for ten minutes, either by unplugging or flipping the household circuit breaker.
Additionally, do you see a lock symbol on your control panel? If you do I would hold that button down for three to five seconds. If that does not correct the issue you are currently experiencing I would recommend seeking assistance from a professional to come and properly diagnosis your appliance. I hope this is helpful. -Matt
Oct 09, 2014 | Frigidaire Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 19, 2014 | Thermador Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
LED says "Locked" can't turn on stove. How do you unlock it?
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 16, 2009 | GE Profile JTP18 Electric Single Oven
OVEN DOOR LOCKED
IN THE CONTROL PANEL ON THE STOVE CLICK ON THE CANCELBUTTON AND LET THE STOVE COOL DOWN BEFORE YOU TRY TO OPEN.
Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
125 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
