Question about Garmin GPSMAP 276C GPS Receiver
CHECK BEACON WIRING MESSAGE
WILL NOT PROGRESS PAST THE ACQUIRING SATELLITES SCREEN
  • fcorey Feb 28, 2009
    My Garmin GPSmap276C has the same problem. It just stopped acquiring satellites a few days ago and I have no idea why. I have tried to get it to work in several wide open locations to no avail.
ttech
  • 139 Answers
SOURCE: not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Posted on Jul 24, 2007
  • 6 Answers
SOURCE: Trouble Acquiring Satellites
Thank you all for the help. I had already downloaded updates and it told me there weren't any more updates that the unit was current. The bugger just fought me all the way.
I tried the reset address over and over to no avail. Finally after it was completely charged, I set it by a window and left in turned on with the finding satellite or whatever it said on it, and went to bed. By the next morning it knew where I was!
Posted on Dec 25, 2007
SOURCE: having problems acquiring satellites
I know it sounds silly but sometimes when my Nuvi 350 does this, an hour or two in the freezer does the trick.
Posted on Apr 26, 2008
SOURCE: Garmin NUVI 650 acquiring satellites
  • Make Sure the GPS has a good, clear view of the sky. “Clear” does not need to be sunny. Overcast skies have no noticeable impact on GPS performance. But buildings and trees do. So take the GPS outside where you have the biggest sky view as you can.
  • Next, wait for the GPS to acquire a signal. If this is the first time you have used it, expect it to take up to 20 minutes to find a signal. Most often it will take less, but prepare for 20 minute. Now for an important step… Once it has found your location, let it continue to sit there for about 30 minutes.
Posted on Jan 12, 2009
SOURCE: i only get acquiring satellites
after you re set your nuvi, and the "acquiring satellites" is showing on screen: place the unit while on, flat, outside - I placed mine on the outside deck with open skies above! leave the unit in this position for no less than 45 minutes. This is the time the unit needs in order to "acquire" the satellites.
After this, my unit worked perfectly well.
Hope this helps.
JA
Posted on May 06, 2009
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
My c340 stops at "locating satellites". I reset it
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
My screen will always states "acquiring satellites"
Have you updated your Garmin in a while? To update it you need to download their Webupdater program from their website.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
From here follow the instructions. A simple update of your GPS may fix this problem.
May 20, 2009 | Garmin nuvi 260W GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Not acquiring satellites
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 276C GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
