Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Replaced sprocket and worm gear on chamberlain 1/2 opener
Put the chain back on and tryed it. the door foward hard then backed off i tryed the limits and the adjust nothing
  • Anonymous Feb 22, 2009
    old unit hbw0777. after replacing drive/worm kit door in down position. when power switch was engaged chain jammed forward. had to remove chain recheck installation procedures. tried again, same results.
    NOW WHAT!
    I replaced the sprocket/worm gear on my Lift-master 1255, but after replacing the chain, garage door goes up about 6 inches, and reverses closed automatically. None of the adjustment screws offer any difference!
    Problem Solver:
  • 8 Answers
The easiest way to fix this would be to take the chain off the sproket with the door and the trolley in the down position. Next hit the wall button and pay attn. to weather the gear is turning clockwise, you want it to turn that direction, wait until the unit stops by itself, next put the chain back on and now you should be able to adjust the limits. otherwise you should call a local professional. They will usually service your door as well as fix your opener.
Posted on Feb 27, 2009
My garage door chain came off, i put it back on
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
The chain normally comes off when there is a problem with the sprocket and gear assembly. The bearing goes bad and lets the shaft lean towards the door and the chain comes off. If this happens again you will need to replace that assembly which is part #41C4220A and is available at any good door service company.
Jul 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 4200C doesnt open or close properly
You did not sync the chain correctly. If you have not touched the travel limits, take chain off sprocket and run door to either up or down position. Put chain back on with trolley in up or down, accordingly. Tension and make final travel adjustments.
Mar 07, 2010 | Liftmaster, Chamberlain, Sears Door...
I replaced the sprocket and gear assembly on my
Here are some things to check.
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I recently replaced the gear drive on my craftsmen chain drive opener. However, now the opener only moves a couple of feet and then returns back. adjustments dont work. What is the problem?
You should also loosen the chain enough that you can remove it from the sprocket above the motor. Now with the door closed and everything else attached run the motor until it runs clockwise and stops. Replace and tighten the chain. Some adjusting of the up and down limits will be required.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Stuck garage door - Sears Craftsman 1/2 HP GDO, Model 139.18876
You have to sync the limit switch with the trolly. Take the small white piece off the bottom of the gear and sprocket assembly. Rotate the center screw on the limit switch until it is all the way up. Put the chain back on the sprocket with the trolley in the up position. Put the small white piece on the bottom of the gear and sprocket assembly. Operate the opener with the trolley dissconnected from the door. You will have to adjust the limit screws on the side of the opener accordingly.
Feb 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Help! chaimberlain/sears 1/2 hp door opener prob.
Fist, turn down the force settings to half. The force settings can damage the door when turned up that high.. Your problem is with the limit settings. This is the three white screws on the bottom with the cover off. You will have to take the bottom off the gear and sprocket assembly and place the limit in the position that the trolley is and adjust the other two screws accordingly.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
460 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
