Question about Sharp Televison & Video
Sharp Aquos Power Supply
Online research suggests the power supply on my Sharp LC-46D64U is bad (power LED blinks 2x/sec and OPC LED blinks 1x/sec). Power supply p/n is DPS-304BP-1 (a/k/a RDENCA235WJQZ).
The symptoms are when you plug in A/C, the relay clicks once and then the front panel LED blink. Activating the power switch on the set results in same behavior (i.e. relay click & LED blink).
Visual inspection of the p/s board does not show signs of any failed/damaged components, hot spots, cold solder joints, or smell - it looks just fine. I'm out of warranty.
I would like to confirm the p/s is indeed the problem before buying a replacement. I haven't found any schematics/technical info to aid in troublshooting. Voltage measurements indicate the primary side is getting good 120VAC from the DC-2541-1A (a/k/a RUNTKA317WJQZ) board & I've measured some 5VDC and 3VDC points on the secondary side, but I have not found any 15VDC or 60V or any other voltages (which I suppose could be due to the fact p/s is not "starting" up).
Does anyone have a schematic or technical information or suggestions on troubleshooting the p/s so I can purchase a replacement board with confidence?
Thanks.
  • nypflznut Dec 11, 2009
    I ended up swapping out the power supply board back in Feb. and it's worked just fine ever since. Disappointed this was a problem after only 16 months of use.
2 Suggested Answers
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
I have a Sharp lc-46d62u and it blinking when i power it up the power led and the opc led blink twice a second the the opc led blinks and repeats. I read on this site that it may be the power supply so i...
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)...
Nov 01, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46D43U no pic no sound
I have the same problem right now and i dont understand the solution. help?
Jul 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
May 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Tv shutting off
it sounds like it may be a capacitor problem and it may be linked to the electricity you receive adding a battery back up of sufficient quality will smooth out the electric current and also **** up the spikes from the power and light company. I have seen many aquas suffer from capacitor failure but it may be an expensive fix.
check your electric output and see if it can handle the load for this tv.
Apr 28, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Lc-46d64u
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, youd have to call Sharp to locate a local service center.
Mar 23, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos TV
The tv wont turn on ... the gren power display keeps blinking and won't turn on...
What can I do? Thank-You! KarL
Feb 24, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Tv shutting off
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
3,532 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
