Question about Hisense TA42P40M 42 in. Plasma Television
Have a 42 inch Hisense plasma tv and a problem with two thin horozontal lines about 6 inches from top of screen.TV is 3-4 years old.
    Sergeant:
  • 250 Answers
Those are retrace lines, the vertical section is supposed to blank them out through bias .
An electrolytic capacitor is most likely going bad. It's not a biggy, the TV won't blow up, but the lines will continue to get worse.
other wise it can also be the cause of
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417.
If you have an electronics background you should be able to find the defective ones with an ESR tester .
a answer of some body who solved it manually just read it
A thin horizontal black line appeared about 1/3 of the way down from the top of the screen. Shortly after that another thin line appeared beside the first one. I pulled the back off of the TV (many little screws) and started pushing connections around. The line would disappear every time I pushed on the connectors hooked to the Y board (the board on the top left side when looking at the back of the TV. The line would keep coming back, so I drilled a hole in the cover so I can put my finger through the hole and push on that connector when the lines come back. It has worked perfectly so far. If I knew how to add a picture to this comment I would. Hope this helps somebody.
Posted on Feb 15, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
At best described, plasma repairs is challenging. Your described condition could indicate a number of possibilities. It could be as simple as noise in the video signal or in the A/V board. It could even be a loose connection or simply require changing ports/jacks. It using HDMI, try using a different one. Or worst a problem with the mainboard.
Two ways to initially address the problem:
  • DIY (do-it-yourself) repair. This would require familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron. It would be to your advantage to have access to a Service Manual or at the very least a schematic diagram with voltage measurements;
  • seek the services of a qualified professional for a repair quotation.
While it would be possible to effect your own repairs, there would be the above mentioned pre-requisites; otherwise, it would be guess work and unfortunately may lead to false diagnosis/parts replacement. A quote on the other hand would cost depending on the going rate within your location. The advantage is that you would have an idea of the possible cost of parts and service fee. This would be significant since this information factored in with the TV's age, downtime, efforts to have the TV repair would present you an evaluation of your options or even consider replacing the unit entirely.
If you are considering DIY, pls post back. Good luck and thank you for using FixYa.
    Sergeant:
  • 326 Answers
Its the problem of the main board capacitor internally .near to the end of its life and gone weak.will get totally faulty soon.before that get it replaced to avoid further major problems.
  • Hisense Master
  • 19,396 Answers
Try connecting using a different cable first.
  • Ginko
    Ginko Feb 15, 2009
    Try first using a different cable to connect.
    If that does not work it is likey to be the Zsus card faulty, or a problem with the video chipset on digital board.
A LINE JUST APPEARED DOWN THE LEFT HAND SIDE OF THE LCD, IT IS BLUE, IT IS A MATSUI 42 INCH LCD ONLY 1 YEAR OLD. IT IS ONLY A THIN LINE BUT GOES FROM THE TOP TO THE BOTTOM OF THE SCREEN.
There is something that is wrong with your LCD panel. The only way to fix it is to replace the whole LCD panel which is very expensive ($500+) and time consuming (need to take whole TV apart).
Oct 08, 2009 | LG DU-42PY10 42 in. Plasma HDTV
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Quite some time ago my 42 inch LG plasma developed thin rainbow lines on the left side - now i have 2 1.5 inch vertical lines dividing my screen into 3 sections. can this be fixed ? and at what cost ?
How old it ur tv,ur plasma bulbs might need be replace.Could be the plasma tube it bad because long times use.But ur plasma screen it self could damage kind radiation not worth repairing.
U alway make deal with the repair man come out for estimate.Cost u like u repair with him.
Make sure ask him come out for no cost some charge $40 come out.
Aug 12, 2009 | LG 42PC3D 42 in. Plasma Television
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hisense 42in plasma flashing blue/green pixels after 30 mins
Do a master reset
1. unplug the TV from the wall
2. remove the batteries from the remote
3. wait 24 hrs
4. plug TV into the wall socket
5. install batteries in remote
6. hold power on button for minimum 10 seconds
This was given to me by the Hisense service line and worked for my TV.
Aug 11, 2007 | Hisense TA42P40M 42 in. Plasma Television
Hisense TA42P40M 42 in. Plasma Television Logo
151 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
