Question about E-Machines eMachines Desktop PC
Memory size what is the maximum size memory you can put into a emachines 140 dvd pc desktop?
  • r_jprice Feb 15, 2009
    spot on thanks very much 4 that
  • 77 Answers
512MB is the Maximum memory amount given by Emachines for this unit.
Posted on Feb 15, 2009
  • Randy
    Randy Feb 15, 2009
    No problem :)
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
Installing a 512mb PC133 memory module in a t1090 emachine. The pc wont recognize the module and wont boot nor go into post. Switching back to the original two 128mb modules and the pc works normal. Is...
Hi there
Your t1090 will only accept a maximum chip size of 256Mb and so it will not accept the added the 512mb chip as it cannot handle it. 512 is the maximum size of RAM for this machine but unfortunately you cant put it in in one go
Jul 03, 2010 | E-Machines T1090 PC Desktop
I have a emachines 733i running xp... how much ram can I add?
The maximum ram you can put is 256mb. Your machine comes with two memory slots. You have take whatever that is in the memory slots and replace them with 2 pieces of 128mb module. Each module will cost around $13.
Hope this helps!
Jun 24, 2010 | E-Machines etower 733i PC Desktop
How do I open my emachines ez1601-01 all in one pc
Go to the Crucial site. They make memory and their site will scan your PC, then tell you how much memory it will take.
From there, it will also give you an idea of how to open your PC to install the new or additional memory.
www.crucial.com
Good luck,
-a.
Jun 24, 2010 | eMachines EZ1601-01 All-in-one PC 18.5'...
I computer is slow and a message that my virtual memory is low
1. Click Start, right-click My Computer, and then click Properties.
2. In the System Properties dialog box, click the Advanced tab.
3. In the Performance pane, click Settings.
4. In the Performance Options dialog box, click the Advanced tab.
5. In the Virtual memory pane, click Change.
6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
Click OK and close .
Oct 11, 2009 | E-Machines eMachines Desktop PC
What are the exact instructions for upgrading my
Crucial has a very good guide:
http://www.crucial.com/install/dimm.aspx
And they also have a auto system checker that will detect current ram Spec's and show you whats available .
http://www.crucial.com/systemscanner/index.aspx
Jun 09, 2009 | E-Machines eMachines Desktop PC
How do I upgrade memory on a t1100 emachine from 256mb
Your emachines eMachines T1100 only supports modules made with a specific type of chip. Should you find what seems to be the exact same memory elsewhere for a lower price, it is very possible that the cheaper memory will not work in your computer. From what I see you should use straight PC-133 Try a site like Kahlon.com-they make sure it works with your computer as would kingston or corsair...
Your maximum amount of ram is only 256mb total.
hope this helps...good luck- please leave a rating...thank you kindly
Apr 26, 2009 | E-Machines T1100 PC Desktop
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Ram upgrade
In most cases if you put of not thesame capacity in any computer later will create further problems. it can damage the other memory or both and the worse is when also the motherboard will also damage.
That is why im telling you this. Please prevent inserting memory of two or three different capacity. You should not do that.
You should select etheir use all 256mb or all 512mb or all 1gb.
in the T4200 since max. is 1.5gb, either use 3-512mb if can carry the maximum if not , then use only 2-512mb.
in T3624 since max is 2GB. You can try 2-1gb if can carry the maximum if not, use only 1-1gb.
Note:
You can use or inserting at different capacity but is at your own risk. "
Ps. does no matter either you put smaller or bigger in first slot.
Mar 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
