Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3t Washing Machine display panel flashing
Problems began a couple weeks ago. Machine wouldn't drain all the way. Then the display panel started flashing and the door wouldn't open. I unplugged it and plugged it back in. No help. Now there is nothing on the display panel and the door is still locked. Any ideas?
  • Anonymous Apr 21, 2009
    Help..our front load washer..which we have had problems with before, isnt' spinning..draining, etc. It is trying to spin..you can hear that from behind, but nothing is happening. I couldn't open the door, the panel was flashing and beeping. I finally got the door open and had to bring my soaking wet clothes to the neighbors. There is still water in the bin. WE have had problems before with it not draining. Can't get anyone out to fix it! HELP
    Problem Solver:
  • 14 Answers
CHECK FUSE IN PLUG,PUMP, DOOR INTERLOCK
Posted on Feb 15, 2009
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
HE3T WILL NOT GO INTO SPIN PUMP TAKES A LONG TIME KEEPS SHOWING A CODE OF F02
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Kenmore HE3T Washer
The F02 keeps flashing M#110.42832 CSM#1004028 pls help
Kevin
Feb 09, 2011 | Kenmore HE3T Washer
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
Control Panel is locked on Kenmore Elite Washing Machine. HE3t
push and hold the drain/spin button on the lower left for at least 3 sec's per mfg instructions
Nov 28, 2009 | Kenmore Washing Machines
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
We have a Kenmore Elite HE3t front loader washing machine.It has had water remaining in it after a load has finished twice now. I run it spin/drain and it is gone. Haven't had the problem for a few loads...
Hello. You sound like you have one of two problems.
The bottom panel on your washing machine has 3 screws on the bottom part of it that hold it on. You will need to remove these screws and the panel. On the right hand side you will see a plastic pump assembly. Since you have alot of water in the washer, you will need to lean the unit back at about a 45 degree angle so water won't go everywhere. Unscrew the front of the pump using the handle on it. It is either clogged up OR bad. If it is not clogged up, you will need to replace it. Send me the model number and I will get you the part number.
Jul 15, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t- suds-
advance machine to drain/spin cyce to remove the water.if it doenst drain and just "humms". try removing the lower access panel. just behind it youll find the pump assy unscrew the face and empty the contents (probably lint, baby bock, assorted stuff from pockets)be prpared though the hose above is FILLED with water. Make sure your using HE detergent!!!!!!!!!!
Mar 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
373 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
