Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I moved and mixed up my adapters.
What is the power rating on the AC Adapter for the Sea free agent pro M series external drive. thnx. I have the adapter but its mixed up with other adapters
  • 3,051 Answers
Hi there;
Nomaly there is a sticker on the bottom of the unit that gives the power rating and it will tell you how much power the device has input and out put all of the information will be there for you ok best regards mike
Posted on Feb 16, 2009
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
I have a Segate Free Agent Desk 1TB External HDD. Today when I plugged it in the power supply, the LED light keeps on blinking. The Drive is not getting detected by my Laptop. I tried it on my Desktop, But...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 30, 2010 | Seagate FreeAgent Pro 1TB External USB...
My Seagate Free Agent GO is not working. My laptop does not detect my external hard drive and external hard drive does not power up. Before it used to work good.
Either the power outlet it is plugged into does not have power or the AC power adapter for the drive has failed. Try another outlet. If that doesn't work see if Radio Shack has a replacement AC adapter or contact Seagate to replace it.
I hope this helps.
Nov 30, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Simpletech external 320 gb... keeps burning out the ac adapters!!!.... WHY?
May be the device requires a higher power rating.
Try to change the power adapter unit with a higher Current value
Mar 15, 2010 | SimpleTech Signature Mini 250GB External...
Seagate 1TB Free Agent Quit Working
It looks like its just the ac-adapter that is dead.
I would contact the store you bought the harddrive, and ask if they just can send you a new ac-adapter.
Btw backup means that you have saved your data 2 places.
Best regard -r0lfi
Jul 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Seagate Free Agent M Series 750 GB external hard drive. In using it yesterday, I connected to my computer and it was fine. After about 20 minutes the unit shut itself off and now has no power to...
First step, check the power cord, if you have a multi meter, set it to the 20v range DC and test the AC adapter for voltage.
If it is dead you may be able to get a replacement but it's likely cheaper to move the drive into a new enclosure(see the next step)
Stop in at your local computer store, ask the techs to sell you a SATA HDD enclosure and either move the drive into it for you, or if your feeling handy take it home and give it a try yourself(this WILL void Seagates warranty)
Once the drive is in the new enclosure, hook it up to the computer and see if it works, if so you're done. If not, send it to a pro for data recovery. In North America I always recommend Armot-IT Data Recovery(in FixYa Database), if you're in another region add a comment here and I will make an appropriate recommendation.
Hope this helps FixYa,
May 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Power requirement to identify the right transformer among many
Output voltage is 12 volts at 2 amps. 24 watts.
See if it looks like this,
May 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Power problem
just reading this forum I think I have bought a total POS. Damn! wich i would have read this first. This boat anchor has all of my backup on it, is only a month old and is now junk. What is this the 3rd world's way of collecting all of our data when we return them?
Apr 27, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
146 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
