Lexmark 4425-001 5470 Inkjet Printer P/N: 4425-001 - Originals Logo
Bill Posted on Feb 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
X5470 won't turn on.
When I press the power button nothing happens. There is 30 vdc at the adapter outlet. A lite pole in front of the house was struck by lightning awhile ago and I'm wondering if there is a fuse inside the printer but I can't get it apart.
Sanath Kumar V
Level 3:
  • Lexmark Master 684 Answers
  • Posted on Feb 23, 2013
Sanath Kumar V
Lexmark Master
Level 3:
Answers
684
Questions
Helped
164909
Points
1521
Just Keep the power Supply connected for 1 Hour and check the adapter whether its Warm or Not and let me know!
Regards,
Sanath
5 Related Answers
Anonymous
  • Posted on Aug 03, 2008
SOURCE: power buitton blinking and wont stop.
have the same problem. power button keeps on blinking and paper doesnt go in.
Anonymous
  • 3 Answers
  • Posted on Mar 24, 2009
SOURCE: lexmark 9575 has no power
Sounds like a bad brick. If you have a computer repair place near you take the machine to them and have them test the brick or try a new power cord. Usually a new cord will take care of the problem. Rarely the plug on the printer goes bad so hopefully it is just the cord.
Anonymous
  • 3 Answers
  • Posted on Feb 10, 2009
SOURCE: Despite being plugged in and the green LED light on, no display on printer
hello I have a Lexmark X5470 printer and the power cord doesn't work I get the green light but I'm not getting any type of power How can I order a new adapter to resolve this problem. There is not response when plugged in useally the printer cartridge carriage would jump and move to the right and go to left when ready. I get no response.
Ricardo
YourZEN
YourZEN
  • 820 Answers
  • Posted on Oct 21, 2009
SOURCE: For our Lexmark x5470 All-In-One Printer we are
Overview for Lexmark 5400 series:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See set up sheet (page 1):
http://images.lexmark.com/publications/pdfs/2007/5400/setup-sheet-en-es.pdf
Anonymous
  • 3344 Answers
  • Posted on Jun 11, 2010
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: my lexmark all in one printer x5470 keeps jamming
    Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
    Hp pavilion desktop won boot
    test the power cord+ outlet for faulty with multimeter. However if this things are o.k You must test the power supply pack for faulty, test the 5 vdc+12vdc, etc and see if there are Faulty. and replace. Please tight cable or connector inside. Test too the small battery for CMOS for +3vdc and replace.
    God bless you
    My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
    It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
    Crosley CAWC529PQ1 won't turn on.
    First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
    Here is the board to order.
    1helpful
    Vostro 1400 won't turn on
    I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
    Sony PCG 2F8L won't start
    USE IT WITHOUT THE BATTERY AND REPLACE THE BUTTON
    X5470 constantly is powering on and off
    Please try the steps below:
    1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
    2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
    3. Re-plug the power supply into the printer.
    4. Press the power button if the printer won't automatically power on.
    If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
    Inspiron 2305 power cord doesn't turn the desktop on
    After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
    4helpful
    My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
    TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
    • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
    turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
    • Unplug TV. Wait five minutes. Plug it in again.
    Good morning, i was printing and the printer shut
    Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
    5helpful
    5answers
    HP PhotoSmart C4180 All-in-One... Problem:
    Try the resetting the printer to factory defaults.
    Steps:
    1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
    2.Then, Press and hold the ON button for 30 -60 seconds
    3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    Please let me know, the status. GoodLuck cheers!!
    Thank you ...
    Top Lexmark Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
