Question about Maytag Atlantis MDG7400AW Gas Dryer
How to change belt
How to open dryer to change belt
    Problem Solver:
  • 14 Answers
FROM BACK PANNEL
Posted on Feb 15, 2009
  • teddymorris Feb 15, 2009
    FROM BACK PANNEL
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
My kenmore electric dryer turns on and heats but the drum doesn't turn?
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
May 23, 2011 | Kenmore Dryers
Change belt
Here is how to open the dryer to change the belt on the link below.
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
Apr 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What's the easiest way to open up a dlb6850 dryer to check the belt?
Unplug the dryer.
The easiest way to check the belt is remove the plate on the lower rear of the dryer. Look in to see if the belt is attached around the pulley wheel.
The only way to change the belt is to remove the screws in the front panel. Open the door. Look up in the door opening and remove these screws. Then you can raise the lid.
If the belt needs changing you must remove the 2 screws in the top right and left sides of the front panel.Just inside the front panel.Then disconnect the door switch wires and remove the front panel.
Slip the belt over the drum. Then open the lower rear panel to reach in to put the belt around the tension pulley.
Nov 12, 2009 | Hotpoint Dryers
Need to change belt on maytag dryer but dont know how to do it on this model . any help would be great
Get the Model number and order a Dryer Maint Kit from either of these sites.
http://www.partselect.com/
http://www.repairclinic.com/
If you have the belt already then open the dryer door and there should be a couple screws in the opening where the door normally closes at the top. Remove those and then the door should be able to completely come off then you will have access to the belt area.
Good Luck!
Nov 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing belt on my dryer
I am not familiar with this particular dryer, but all electric dryers are designed so that the consumer can replace the belt. Open the access door ( the back, the top, or the removable panel at the bottom front) and the belt should be visible; a few minutes of study will show you what you need to do to change it.
Apr 22, 2009 | Candy CDV262 Dryer
Changing dryer belts. How do I open the dryer to change the belts? I think one of them are broken.
either the top pries up or you'll have 2 screws at the very bottom of the front panel from there you can remove the front panel but make sure you disconnect the door switch wires before yanking the front panel away
Mar 11, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer belt routing
the best way i can tell you is open the back put the belt on the motor then visually pull the tension pulley back and put the belt on the tension back on the belt. if you are changing the belt you must touch the spring.let me know how it goes.
Nov 11, 2008 | Dryers
REPLACING THE BELT
Hi thanks for the question. to replace the belt. open the door. screws on the inside, under top. remove screws . lift the top. 2 screws on the inside, of front panel. remove. pull front off. now replace the belt. thanks the appliance doc. please rate me. thanks
Oct 05, 2008 | GE DCSR483EA Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
105 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
